installation OF-1.7.1
Old   November 10, 2010, 08:19
Default installation OF-1.7.1
lynda
lyna is on a distinguished road
I'm trying to install OF-1.7.1 on a 32 bit PC with ubuntu 10.04, but I have trouble with setting the path.
Here 's the message I get after using the checking system script foamInstallationTest :
WARNING: Conflicting installations:
OpenFOAM settings : /home/lynda1/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linuxGccDPOpt/icoFoam
current path :
CRITICAL ERROR
Could anyone help. Thanks.
Lyna
lyna is offline   Reply With Quote
Old   November 10, 2010, 19:08
Retired Super Moderator
Bruno Santos
Greetings Lyna,
Read this post: Building OpenFOAM1.7.0 from source post #4 and onward
There you'll find which packages you need to install for building OpenFOAM in Ubuntu The rest is as simple as following the page you were reading in www.openfoam.com.
Also, when running Allwmake, you might want to run it like this:
./Allwmake > make.log 2>&1
This way you will keep a log of the build process and in case there are errors, you can compress it and post it here, so we can figure out what happened.
Best regards,
Bruno
[OpenFOAM.com] OpenFOAM 1.7.1 installation on LINUX UBUNTU 10.10 electrosin OpenFOAM Installation 40 May 31, 2016 05:11
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
OF 1.7.1 installation problems goma OpenFOAM Installation 20 December 11, 2010 08:22
Installation of OpenFOAM 1.7.1 to OprnSUSE 11.2 superfxfund OpenFOAM Installation 3 November 11, 2010 02:15
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
