Courant numer
Old   September 1, 2010, 07:17
Default Courant numer
inginer's Avatar
Ovidiu Michiu
inginer is on a distinguished road
I'm trying to do my first case in OF. I converted a mesh from fluent, an airfoil 2D, compressible flow with M=0.8, Spalart-Allmaras imposed and a Courant Numner=200 in fluent. I adapt an compressible case from tutorials of OF, /sonicFoam/RAS/naca. I can see the mesh without any problems, but I don't know how can I calculate the time step, delta t from /system/controlDict.
The second problem regards the thermophysicalProperties definition. I read the tutorial but when i started to write my thermophysicalPropoperties i got stuck; I have sutherland law imposed and perfect gas; how can i calculate all the coefficients to have a good thermoProp correct?
Thk,
Best Regards,
Ovidiu
inginer is offline   Reply With Quote
Old   September 1, 2010, 09:50
colinB is on a distinguished road
The courant number is defined like this:
C = (U * delta t) / delta x
with U = velocity of the liquid/ moving wall what ever
delta t you want to calculate
and delta x = domain length [m] / Number of Elements in x direction
for more details see here:
http://www.openfoam.com/docs/user/cavity.php
chapter 2.1.1.4 Control
It happens to be the first tutorial.....
colinB is offline   Reply With Quote
Old   September 1, 2010, 10:42
inginer's Avatar
Ovidiu Michiu
thk colinB,
i check the tutorial before posting the thread.
the problem is that i don't know the cell size, delta x. i receive the mesh from fluent, i didn't do the mesh and i don't have fluent install on my pc to see the cell mesh.
Best,
Ovidiu
Old   September 2, 2010, 03:25
akidess's Avatar
Anton Kidess
After conversion you can run checkMesh, and then get information about cell volumes. For a rough estimate of the Courant number you can take the third root of the cell volume.
Old   September 3, 2010, 10:55
Sabin Ceuca
sabin.ceuca is on a distinguished road
Hi Ovidiu,
you can actually plot the cell Volumes using the variable mesh.V() and then compute the dx you like best
Ciao,
Sabin
sabin.ceuca is offline   Reply With Quote
RMS Courant Number vs MAX Courant Number zoozoozoo Main CFD Forum 3 June 12, 2012 13:44
Problems with Courant number (LaunderGibsonTurbulence Model) sven OpenFOAM 3 August 10, 2009 03:12
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
pls help fluctuating residuals due to courant no sagar CFX 3 March 28, 2006 01:10
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
