Home > Forums > OpenFOAM
sample utility problem
Old   April 16, 2012, 14:40
Caroline Vandame
CaroVandame is on a distinguished road
But doesn't the error message means that the keyword patches should be defined in the surfaces section?
"keyword patches is undefined in dictionary "/home/caro/OpenFOAM/caro-2.1.0/run/pipe_flow/system/sampleDict::surfaces" "
CaroVandame is offline   Reply With Quote
Old   April 16, 2012, 14:45
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
It couldn't find the keyword "patches" and checking the dict given with the source code, this keyword is present only in the sets section. The idea is to try adding something in this section to see what happens.
Regards
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Post-doctoral Fellow
Research Center for Computational Mechanics (CIMEC) - CONICET/FICH-UNL
T.E.: 54-342-4511594 Ext. 1005
Güemes 3450 - (3000) Santa Fe
Santa Fe - Argentina
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   April 16, 2012, 14:56
Caroline Vandame
so using the tutorial LadenburgJet60psi as a guide (because they also want to sample for a wall property), here is what I wrote
sets
face
name cyl_Wall;
axis x;
start (0 0.05 0);
end (10 0.05 0);
nPoints 100;
But now I get this error:
keyword type is undefined in dictionary "/home/caro/OpenFOAM/caro-2.1.0/run/pipe_flow/system/sampleDict::sets"
I must be missing something obvious, I just don't see it...
Old   April 16, 2012, 14:59
Yes,
type uniform;
at the beginning of the definition.
Old   April 16, 2012, 15:02
Caroline Vandame
And now I get my "keyword patches undefined ..." error again...
Old   April 16, 2012, 15:05
What FOAM version are you using?
Old   April 16, 2012, 15:06
Caroline Vandame
OpenFOAM 2.1.0
Old   April 16, 2012, 16:13
Please check:
/opt/openfoam<your_version>/applications/utilities/postProcessing/sampling/sample/sampleDict
in order to see the correct wording of the dictionary, the keywords have changed in the last versions. Now the keyword patches is required in surfaces too.
Regards.
Old   April 16, 2012, 17:24
Caroline Vandame
Thanks so much for your help Santiago!!!
It seems you do not need to specify anything in sets, as long as everything is defined correctly in surfaces.
Old   April 16, 2012, 17:27
You welcome. Yes, sets is not more needed. It was used only for testing purposes.
Bye.
Old   June 6, 2012, 20:42
Default sampleDict surfaces with moving mesh
  #31
cutty4sark is on a distinguished road
I was wondering if anyone has used the sampleDict to determine variable values along a moving mesh. Particularly, I'm interested in the displacement of a solid in an FSI case (Turek and Hron benchmark). It would be very similar to determining the displacement of the tip of the console in the flappingConsole FSI case that is packaged with the extend versions of 1.5 and 1.6. I've tried using the surfaces functionality of the sampleDict and like many other folks end up with empty file folders. This leads me to believe there are issues with trying to use the boundaries/interfaces between solid and fluid as my surface patch like others have experienced. This also brings me to the issue of trying to define a line or surface based on xyz coordinates as I'm interested in the variation of x,y,z over time as the solid is deflected. Any help would be appreciated and I'm curious if anybody else has experienced this as I couldn't find anything in the forums.
Regards,
Andrew
cutty4sark is offline   Reply With Quote
Old   September 13, 2012, 03:00
Default About installation of swak4Foam
  #32
M Mallikarjuna Reddy
mmkr825 is on a distinguished road
Hi everyone,
I am fresher to openFoam. I came to know the uses of swak4Foam utility for writing boundary conditions. In my application also i need to apply zero flux boundary condition. So i wish to install swak4Foam. Now i am working on OF 2.1.1 version.
I followed every step as mentioned in the tutorials but i am not able to get it. The error message as follows
Error message:-
malli_reddy@ubuntu:~/OpenFOAM/malli_reddy-2.1.1$ svn checkout https://openfoam-extend.svn.sourcefo...ies/swak4Foam/
svn: OPTIONS of 'https://openfoam-extend.svn.sourcefo...ries/swak4Foam': Could not resolve hostname `openfoam-extend.svn.sourceforge.net': No address associated with hostname (https://openfoam-extend.svn.sourceforge.net)
Could you please suggest me how to overcome this problem. And suggest me some good tutorial for the swak4Foam.
Thanks
Regards
mmkr825 is offline   Reply With Quote
Thread Tools
Trackbacks are On
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Sample utility Gearb0x OpenFOAM Post-Processing 12 March 27, 2011 14:13
Sample utility not working properly titio OpenFOAM 2 June 9, 2010 10:45
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
