sonicFOAM for an airfoil error
I'm trying to do a sonicFoam case in OF 1.7.0 with a mesh imported from fluent. it is an airfoil 2d with M=0.8. after building the case i try to run it and i receive the following error openfoam@linux-bkii:~/OpenFOAM/openfoam-1.7.0/run/projects/cmyairfoil> sonicFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.7.0 | | \\ / A nd | Web:www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 1.7.0-21131bcbd876 Exec : sonicFoam Date : Sep 07 2010 Time : 16:10:12 Host : linux-bkii PID : 8245 Case : /home/openfoam/OpenFOAM/openfoam-1.7.0/run/projects/cmyairfoil nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading thermophysical properties Selecting thermodynamics package ePsiThermo<pureMixture<sutherlandTransport<specieT hermo<hConstThermo<perfectGas>>>>> Reading field U Reading/calculating face flux field phi Creating turbulence model Selecting turbulence model type RASModel Selecting RAS turbulence model SpalartAllmaras SpalartAllmarasCoeffs { sigmaNut 0.66666; kappa 0.41; Prt 1; Cb1 0.1355; Cb2 0.622; Cw2 0.3; Cw3 2; Cv1 7.1; Cv2 5; } Starting time loop Time = 2.13e-09 Courant Number mean: 5.01425e-06 max: 0.00279144 #0 Foam::error::printStack(Foam::Ostream&) in "/home/openfoam/OpenFOAM/OpenFOAM-1.7.0/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/openfoam/OpenFOAM/OpenFOAM-1.7.0/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/home/openfoam/OpenFOAM/OpenFOAM-1.7.0/lib/linuxGccDPOpt/libOpenFOAM.so" #4 Foam::operator/(Foam::UList<double> const&, Foam::UList<double> const&) in "/home/openfoam/OpenFOAM/OpenFOAM-1.7.0/lib/linuxGccDPOpt/libOpenFOAM.so" #5 Foam::diagonalSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/openfoam/OpenFOAM/OpenFOAM-1.7.0/lib/linuxGccDPOpt/libOpenFOAM.so" #6 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/home/openfoam/OpenFOAM/OpenFOAM-1.7.0/lib/linuxGccDPOpt/libfiniteVolume.so" #7 Foam::lduMatrix::solverPerformance Foam::solve<double>(Foam::tmp<Foam::fvMatrix<doubl e> > const&) in "/home/openfoam/OpenFOAM/openfoam-1.7.0/applications/bin/linuxGccDPOpt/sonicFoam" #8 main in "/home/openfoam/OpenFOAM/openfoam-1.7.0/applications/bin/linuxGccDPOpt/sonicFoam" #9 __libc_start_main in "/lib/libc.so.6" #10 _start at /usr/src/packages/BUILD/glibc-2.10.1/csu/../sysdeps/i386/elf/start.S:122 Floating point exception openfoam@linux-bkii:~/OpenFOAM/openfoam-1.7.0/run/projects/cmyairfoil> anybody receive a similar error? what i did wrong??? Thk you Ovidiu |
I receive a similar error when trying to run sonicFoam to my case. /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.7.0 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 1.7.0-279cc8e8233b Exec : sonicFoam Date : Sep 08 2010 Time : 00:32:20 Host : PID : 2229 Case : nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading thermophysical properties Selecting thermodynamics package ePsiThermo<pureMixture<constTransport<specieThermo <eConstThermo<perfectGas>>>>> #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam170/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/opt/openfoam170/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: #3 Foam::ePsiThermo<Foam::pureMixture<Foam::constTran sport<Foam::specieThermo<Foam::eConstThermo<Foam:: perfectGas> > > > >::calculate() in "/opt/openfoam170/lib/linuxGccDPOpt/libbasicThermophysicalModels.so" #4 Foam::ePsiThermo<Foam::pureMixture<Foam::constTran sport<Foam::specieThermo<Foam::eConstThermo<Foam:: perfectGas> > > > >::ePsiThermo(Foam::fvMesh const&) in "/opt/openfoam170/lib/linuxGccDPOpt/libbasicThermophysicalModels.so" #5 Foam::basicPsiThermo::addfvMeshConstructorToTable< Foam::ePsiThermo<Foam::pureMixture<Foam::constTran sport<Foam::specieThermo<Foam::eConstThermo<Foam:: perfectGas> > > > > >::New(Foam::fvMesh const&) in "/opt/openfoam170/lib/linuxGccDPOpt/libbasicThermophysicalModels.so" #6 Foam::basicPsiThermo::New(Foam::fvMesh const&) in "/opt/openfoam170/lib/linuxGccDPOpt/libbasicThermophysicalModels.so" #7 in "/opt/openfoam170/applications/bin/linuxGccDPOpt/sonicFoam". Any idea please. |
Hy Bruxellois,
Did you manage to repare the error. I try to do the same case but in incompressible, simpleFoam. the code is running but the results were very strange. The velocity U is from 0 to +infinity and the pressure is from -infinity to +infinity; this is totally wrong, but i can see the error in the code. Maybe OF is not capable to solve transonic case ... Best Regards, Ovidiu |
Hi
Check with your boundary conditions, turbuence model you are using Regards Ambilpur Kiran |
Hello kiran,
my turbulence model is Spalart-Allmaras for compressible flow, the temp is 300K and velocity 277.67 m/s (M=0.8). i check the boundary condition. i receive the same error. i don't have any ideas in what could be wrong. Best Regards, Ovidiu |
attach your case file
regards Ambilpur Kiran |
Hello Kiran,
bellow you will find a link where you can download the case. http://www.2shared.com/file/fVbh4wcU/comairfoil.html Best Regards, Ovidiu |
| All times are GMT -4. The time now is 10:45. |
