[swak4Foam] wmake groovyBC in OpenFOAM 1.7 ?
Old   August 27, 2010, 02:50
Default wmake groovyBC in OpenFOAM 1.7 ?
maxwell
randomid is on a distinguished road
dear all,
i compile groovyBC in ubuntu 10.04 and openFOAM 1.7, i donot know whether it is correct or not, here is the output:
root@food-desktop:~/nwt/groovyBC# wmake libso
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file PatchResult.C
Making dependency list for source file PatchValueExpressionParser.yy
could not open file PatchValueExpressionParser.tab.hh for source file PatchValueExpressionParser.yy
Making dependency list for source file PatchValueExpressionLexer.ll
could not open file PatchValueExpressionParser.tab.hh for source file PatchValueExpressionLexer.ll
Making dependency list for source file PatchValueExpressionDriver.C
could not open file PatchValueExpressionParser.tab.hh for source file PatchValueExpressionDriver.C
Making dependency list for source file groovyBCFvPatchFields.C
could not open file PatchValueExpressionParser.tab.hh for source file groovyBCFvPatchFields.C
Making dependency list for source file groovyBCPointPatchFields.C
could not open file MixedPointPatchField.H for source file groovyBCPointPatchFields.C
could not open file PatchValueExpressionParser.tab.hh for source file groovyBCPointPatchFields.C
could not open file PointPatchFieldMapper.H for source file groovyBCPointPatchFields.C
SOURCE=PatchResult.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -IMake/linuxGccDPOpt -I/opt/openfoam170/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam170/src/OpenFOAM/lnInclude -I/opt/openfoam170/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/PatchResult.o
PatchResult.C: In member function ‘void Foam::PatchResult::uglyDelete()’:
PatchResult.C:97: warning: deleting ‘void*’ is undefined
SOURCE=PatchValueExpressionParser.yy ; rm -f Make/linuxGccDPOpt/PatchValueExpressionParser.C Make/linuxGccDPOpt/PatchValueExpressionParser.tab.hh; bison -ra -v -d $SOURCE ; mv *.tab.cc Make/linuxGccDPOpt/PatchValueExpressionParser.C ; mv *.tab.hh Make/linuxGccDPOpt/PatchValueExpressionParser.tab.hh ; mv *.hh Make/linuxGccDPOpt ; g++ -m32 -Dlinux -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -IMake/linuxGccDPOpt -I/opt/openfoam170/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam170/src/OpenFOAM/lnInclude -I/opt/openfoam170/src/OSspecific/POSIX/lnInclude -fPIC -c Make/linuxGccDPOpt/PatchValueExpressionParser.C -o Make/linuxGccDPOpt/PatchValueExpressionParser.o
In file included from Make/linuxGccDPOpt/location.hh:44,
from PatchValueExpressionParser.tab.hh:65,
from PatchValueExpressionParser.tab.cc:61:
position.hh: In function ‘bool pveerator==(const pvesition&, const pvesition&)’:
position.hh:136: warning: suggest parentheses around ‘&&’ within ‘||’
PatchValueExpressionParser.tab.cc: In member function ‘unsigned char pve::PatchValueExpressionParser::yytranslate_(int) ’:
PatchValueExpressionParser.tab.cc:4941: warning: use of old-style cast
SOURCE=PatchValueExpressionLexer.ll ; rm Make/linuxGccDPOpt/PatchValueExpressionLexer.C ; flex -f $SOURCE ; mv *.c Make/linuxGccDPOpt/PatchValueExpressionLexer.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -IMake/linuxGccDPOpt -I/opt/openfoam170/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam170/src/OpenFOAM/lnInclude -I/opt/openfoam170/src/OSspecific/POSIX/lnInclude -fPIC -c Make/linuxGccDPOpt/PatchValueExpressionLexer.C -o Make/linuxGccDPOpt/PatchValueExpressionLexer.o
rm: cannot remove `Make/linuxGccDPOpt/PatchValueExpressionLexer.C': No such file or directory
lex.ve.c:372: warning: use of old-style cast
lex.ve.c:442: warning: use of old-style cast
from lnInclude/PatchValueExpressionDriver.H:59,
from PatchValueExpressionLexer.ll:3:
lex.ve.c: In function ‘int pvelex(pve::PatchValueExpressionParser::semantic_t ype*, pve::location*, Foam::PatchValueExpressionDriver&)’:
lex.ve.c:9465: warning: use of old-style cast
lex.ve.c:9482: warning: use of old-style cast
lex.ve.c:9495: warning: use of old-style cast
lex.ve.c:9962: warning: use of old-style cast
lex.ve.c: In function ‘int yy_get_next_buffer()’:
lex.ve.c:10141: warning: use of old-style cast
lex.ve.c:10164: warning: use of old-style cast
lex.ve.c:10177: warning: use of old-style cast
lex.ve.c:10198: warning: use of old-style cast
lex.ve.c:10223: warning: use of old-style cast
lex.ve.c:10226: warning: use of old-style cast
lex.ve.c: In function ‘yy_state_type yy_get_previous_state()’:
lex.ve.c:10261: warning: use of old-style cast
lex.ve.c: In function ‘int yyinput()’:
lex.ve.c:10379: warning: use of old-style cast
lex.ve.c: In function ‘yy_buffer_state* ve_create_buffer(FILE*, int)’:
lex.ve.c:10478: warning: use of old-style cast
lex.ve.c:10487: warning: use of old-style cast
lex.ve.c: In function ‘void ve_delete_buffer(yy_buffer_state*)’:
lex.ve.c:10513: warning: use of old-style cast
lex.ve.c:10516: warning: use of old-style cast
lex.ve.c:10518: warning: use of old-style cast
lex.ve.c: In function ‘void veensure_buffer_stack()’:
lex.ve.c:10685: warning: use of old-style cast
lex.ve.c:10705: warning: use of old-style cast
lex.ve.c: In function ‘yy_buffer_state* ve_scan_buffer(char*, yy_size_t)’:
lex.ve.c:10733: warning: use of old-style cast
lex.ve.c: In function ‘yy_buffer_state* ve_scan_bytes(const char*, int)’:
lex.ve.c:10786: warning: use of old-style cast
lex.ve.c: In function ‘void yy_push_state(int)’:
lex.ve.c:10822: warning: use of old-style cast
lex.ve.c:10825: warning: use of old-style cast
lex.ve.c: In function ‘int yy_init_globals()’:
lex.ve.c:10992: warning: use of old-style cast
lex.ve.c:11005: warning: use of old-style cast
lex.ve.c:11006: warning: use of old-style cast
lex.ve.c: In function ‘void* vealloc(yy_size_t)’:
lex.ve.c:11072: warning: use of old-style cast
lex.ve.c: In function ‘void* verealloc(void*, yy_size_t)’:
lex.ve.c:11084: warning: use of old-style cast
lex.ve.c: In function ‘void vefree(void*)’:
lex.ve.c:11089: warning: use of old-style cast
lex.ve.c: At global scope:
lex.ve.c:10809: warning: ‘void yy_push_state(int)’ defined but not used
lex.ve.c:10837: warning: ‘void yy_pop_state()’ defined but not used
lex.ve.c:10849: warning: ‘int yy_top_state()’ defined but not used
SOURCE=PatchValueExpressionDriver.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -IMake/linuxGccDPOpt -I/opt/openfoam170/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam170/src/OpenFOAM/lnInclude -I/opt/openfoam170/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/PatchValueExpressionDriver.o
from PatchValueExpressionDriver.H:59,
from PatchValueExpressionDriver.C:34:
SOURCE=groovyBCFvPatchFields.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -IMake/linuxGccDPOpt -I/opt/openfoam170/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam170/src/OpenFOAM/lnInclude -I/opt/openfoam170/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/groovyBCFvPatchFields.o
from groovyBCFvPatchField.H:48,
from groovyBCFvPatchFields.H:37,
from groovyBCFvPatchFields.C:36:
SOURCE=groovyBCPointPatchFields.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -IMake/linuxGccDPOpt -I/opt/openfoam170/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam170/src/OpenFOAM/lnInclude -I/opt/openfoam170/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/groovyBCPointPatchFields.o
from groovyBCPointPatchField.H:59,
from groovyBCPointPatchFields.H:37,
from groovyBCPointPatchFields.C:34:
'/root/OpenFOAM/root-1.7.0/lib/linuxGccDPOpt/libgroovyBC.so' is up to date.
root@food-desktop:~/nwt/groovyBC# gcc -v
Using built-in specs.
Target: i486-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Ubuntu 4.4.3-4ubuntu5' --with-bugurl=file:///usr/share/doc/gcc-4.4/README.Bugs --enable-languages=c,c++,fortran,objc,obj-c++ --prefix=/usr --enable-shared --enable-multiarch --enable-linker-build-id --with-system-zlib --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --with-gxx-include-dir=/usr/include/c++/4.4 --program-suffix=-4.4 --enable-nls --enable-clocale=gnu --enable-libstdcxx-debug --enable-plugin --enable-objc-gc --enable-targets=all --disable-werror --with-arch-32=i486 --with-tune=generic --enable-checking=release --build=i486-linux-gnu --host=i486-linux-gnu --target=i486-linux-gnu
Thread model: posix
gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5)
root@food-desktop:~/nwt/groovyBC# bison -V
bison (GNU Bison) 2.4.1
Written by Robert Corbett and Richard Stallman.
Copyright (C) 2008 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
is there anyone know?thanks.
randomid is offline   Reply With Quote
Old   August 27, 2010, 05:15
Assistant Moderator
Bernhard Gschaider
Originally Posted by randomid View Post
dear all,
The magic words are
So everything is OK. The busload of warnings that you're seeing only mean that gcc does not like the source code that bison/flex generates and there is not much that can be done about this
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 05:29
[OpenFOAM.com] erros in Allwmake jiwon OpenFOAM Installation 7 December 30, 2015 12:34
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 06:55
OpenFOAM 1.7 - openSUSE 11.3 - gcc 4.5.0 alberto OpenFOAM 12 July 28, 2010 11:59
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
