September 12, 2010, 03:58 |
openfoam-paraview problem
yair suari
hello forum
i am trying to use openfoam to do some simulation. when trying to run the first example i ran into a problem with paraview. in the tutorial it says i should adjust some options at the region status as seen in figure 6.1 at the user guide. but in my paraview i cant find such option, i only have mesh parts, volume fields, lengrangian fields and point fields. does anyone knoe how i can set this (when i try to look at the results for the lid driven cavity case i cant see any gradients in the interpolated p). just as a comparison this is what my object browser looks like: and this is what it looks like in the tutorials: thanks for your help yair Last edited by yairsuari; September 12, 2010 at 15:38. |
September 13, 2010, 03:31 |
Scott
Try changing the time at the top left to be 1. You have it set to 0 and probably cannot see anything because of this. On a seperate note, does anyone know how I can show the surface mesh in the motorbike case, coloured by pressure on the body, but then also show streamlines? It seems that I need to cache the mesh and select the mesh to have the streamlines, but then it tries to colour the mesh itself when I colour the motorbike. Is there a way that I can apply colour to the motorbike, and then have the streamlines created from the mesh region, without needing to show the surfaces of the mesh (sidewalls, inlets, outlets etc...) Regards, Scott |
September 13, 2010, 04:02 |
thanks scot
yair suari
i am not currently at home
but i played with the time last night and still only saw something in the u field and not in the p field. what does the region selection do anyway and is there another way to select a region? |
September 13, 2010, 05:39 |
Anton Kidess
Rep Power: 29 |
The documentation is older than paraview 3.8. As you can see, the options under region status are the same as the options under mesh parts, and the proper option (internal mesh) is already selected. So with paraview 3.8 you can just skip that step.
September 13, 2010, 06:14 |
thanks alot
yair suari
although now i feel silly
September 13, 2010, 09:55 |
Anton Kidess
Rep Power: 29 |
Don't worry about it, there's a lot to learn after all.
paraview |
Yet another Paraview problem | gascortado | OpenFOAM | 5 | February 21, 2010 06:39 |
Velocity vector data in OpenFOAM and ParaView mismatch | tekky | OpenFOAM | 9 | December 21, 2009 11:26 |
OpenFOAM 1.5.x package - CentOS 5.3 x86_64 | linnemann | OpenFOAM Installation | 7 | July 30, 2009 03:14 |
OpenFOAM Install problem | masb | OpenFOAM | 3 | May 25, 2009 11:32 |
[OpenFOAM] Some problem with paraview | thermo | ParaView | 10 | December 25, 2005 13:20 |
