Home > Forums > OpenFOAM
groovyBC and funkySetFields married and got a kid named swak4Foam
Like Tree11Likes
Old   March 29, 2014, 10:25
akidess's Avatar
Anton Kidess
Unfortunately I didn't keep the logfile, but I think it broke when compiling swak4FoamParsers which allows for three cores. The CPU I compiled this on was a Intel Xeon E5-2650L 0 @ 1.80GHz.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
*Join the OpenFOAM stackexchange Q&A site: http://area51.stackexchange.com/prop...oHPxcPqde7HtA2
Old   March 30, 2014, 08:04
Bruno Santos
wyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nice
Thanks! I've reported this here: https://sourceforge.net/apps/mantisb...iew.php?id=214 - and I'll try to figure out a way to fix this, as I really do like being able to build swak4Foam with multiple cores!
Old   December 18, 2014, 07:38
Default Monitor mass flow for individual phase through outlet
  #163
Paritosh Vasava
vasava will become famous soon enough
I am using openFoam 2.3.0 and running a case which has 4 phases with multiphaseEulerFoam. Is is possible to monitor mass flow rate for all four individual phases using swak4Foam? Could someone post a code that help me get started with this?
vasava is offline   Reply With Quote
Old   January 7, 2015, 17:23
Assistant Moderator
Bernhard Gschaider
Yes it is possible.
Have you already had a look at one of the available presentations about swak?
The only tricky part would be that the new solvers have names for the phases like alpha.air and the dot bothers the parser. You'll have to add an aliases dictionary like
aliases {
  alphaAir alpha.air;
and then you can use a swakExpression like "phi()*alphaAir"
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   January 13, 2015, 03:52
Paritosh Vasava
Thanks for the reply. I will look if I have that presentation if not I will ask for it.
Thread Tools
Trackbacks are On
