dieselfoam - How to print variables?
Old   September 14, 2010, 04:34
Exclamation dieselfoam - How to print variables?
mystix is on a distinguished road
Hallo Foamers,
I try to analyze sprays using the dieselfoam-solver.
And I want to print out some variables (Xratio, denominator, Sh, Nu...) over time, but I dont know how.
Can someone help me please?
Thank you in advance!
Markus
mystix is offline   Reply With Quote
Old   September 14, 2010, 08:05
edison
Edison_Ge is on a distinguished road
My way of achieving this would be add the desired field variable in creatField.H and in the solver assign the related valued to the added field variables. Give it a go, but there may be other smarter way of doing it.
Edison_Ge is offline   Reply With Quote
Old   September 14, 2010, 09:31
The problem is there is no createFields.H file for the dieselFoam solver.
Old   September 14, 2010, 10:30
Palma González García
Palminchi is on a distinguished road
Yes, there is a createFields.H in dieselFoam. If it is not in the dieselFoam directory, it is located in the dieselEngineFoam one. If you check the options file inside the Make dir, you will see that there is a list of routes which mean that when the solver looks for createFields, if isn't in the solver's dir, it will look for it where options file says. Anyway, you can copy createFields.H to your dieselFoam directory and then add the fields or variables you want to have.
Best regards!
Palminchi is offline   Reply With Quote
Old   September 16, 2010, 11:55
Thank you for answers, I copied createFields.H from the dieselEngineFoam to the dieselFoam directory and added the variable Xratio:
volScalarField Xratio
IOobject
"Xratio",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::AUTO_WRITE
mesh,
dimensionedScalar("Xratio", dimless, 0.0)
Now there is a Xratio file in the timestep folder but, the values for Xratio are always 0. That can't be right.
Someone can help me print out the Xratio data please?
Old   September 16, 2010, 13:40
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
I'm currently trying to to figure this out myself. Here, you've created the field and set it to write on timestep output, but it has been initialized with a value of 0 everywhere, and no indication (here anyway) of where this field is calculated.
This variable isn't built in to dieselFoam, have you implemented it yourself elsewhere?
mturcios777 is offline   Reply With Quote
Old   September 17, 2010, 02:14
edison
you'll have to assign value to the new variable in the solver. Just like what happens to velocity U and pressure p
Old   September 17, 2010, 04:22
Xratio is declared, initialized and calculated in
../src/lagrangian/dieselSpray/spraySubModels/evaporationModel/RutlandFlashBoil/RutlandFlashBoil.C
How can I assign the related valued to the added field variables?
Old   September 17, 2010, 09:03
edison
hi Markus,
From what I can understand Xratio is a local variable so you can not assin its value to the new field object you've just create. You can try to make it a class member and then give it a return function. Then you can assign the Xratio value to the new field object.
Take Nu for example, there's a return funtion Nu() for Nu. So in the solver you can assign Nu to a new object, simply write
objectX = turbulenc->Nu();
But i'm not that familiar with c++, there may be a easier way.
injector model in dieselFoam leejc OpenFOAM 8 April 3, 2018 12:30
ADDITIONAL VARIABLES LIMITERS N.P CFX 5 December 1, 2011 07:47
$FOAM_USER_APPBIN & LIBBIN variables not set rassilon OpenFOAM Installation 2 February 16, 2010 20:54
PHI file structure Eugene Phoenics 9 November 2, 2001 22:00
Saving variables on a user patch with physical coordinates Zoltan Turzo CFX 2 April 20, 2000 15:05
