[Sponsors] | |||||
Rep Power: 5 ![]() |
I have a problem with the simpleFunctionObjects in my OF 1.7. I installed step by step descriped by the wiki and add the function in the controlDict. Code:
functions
massFlow
type patchMassFlow;
functionObjectLibs ("libsimpleFunctionObjects.so");
verbose true;
patches
//inlet_1
//inlet_2
//inlet_3
outlet
//factor 19.7363;
Reading field p_rgh Starting time loop #0 Foam::error::printStack(Foam::Ostream&) in ".../OpenFOAM-1.7.0/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::sigSegv::sigSegvHandler(int) in ".../OpenFOAM-1.7.0/lib/linux64GccDPOpt/libOpenFOAM.so" #2 __restore_rt at sigaction.c:0 #3 ?? in "/home/user/OpenFOAM/user-1.7.0/lib/linux64GccDPOpt/libsimpleFunctionObjects.so" Segmentation fault! Any ideas regarding source of error? |
#2 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 30 ![]() ![]() |
Bernhard |
Hi Bernhard, solver was: buoyantSimpleFoam But i tried also a simple tube with simpleFoam with the same result (segfault). The error turn up before the first time-step. It is in order how I quoted. The patch 'outlet' is definetly there.
Assistant Moderator
Bernhard Gschaider
Strange. Could you please post a report plus a small example-case to the OF-extend-Mantis and I'll have a look
Thank you for the help. I will do it tomorrow at work. But I'm not sure what you mean with OF-extend-Mantis? To prevent some mistake. I'm not using the full OF-extend package. I have only download the 'simpleFunctionsObjects' and added them to my local OF-1.7.0 (CentFOAM) Installation.
[code]
user@xxx simple_rohr$ simpleFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.7.0 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 1.7.0-5773603db906 Exec : simpleFoam Date : Sep 23 2010 Time : 10:04:44 Host : W71C-FRGHC0010 PID : 18166 Case : /workDir/simple_rohr nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting RAS turbulence model SpalartAllmaras SpalartAllmarasCoeffs { sigmaNut 0.66666; kappa 0.41; Cb1 0.1355; Cb2 0.622; Cw2 0.3; Cw3 2; Cv1 7.1; Cv2 5; } Starting time loop Speicherzugriffsfehler [\code] Speicherzugriffsfehler = segfault I have report it at OF-extend-Mantis with the simplest case. I hope the informations are enough. |
Hi Bernhard,
because of newer knowledge I'm 'sure' that the 'simpleFunctionObjects'-package is NOT the problem. It seems that my installation/wmake work not correctly. For more informations look:check wmake in CentFOAM |
#8 | |
Assistant Moderator
Bernhard Gschaider
Should the problem with the simpleFunctionObjects persist once you resolved that installation problem feel free to reopen the bug Bernhard |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| How to use setField to create sphere | sega | OpenFOAM Pre-Processing | 37 | February 9, 2013 12:19 |
| Flow simulation in porous media | olesen | OpenFOAM Running, Solving & CFD | 18 | November 20, 2012 02:10 |
| changeDictionary segfault 1.6.x | wikstrom | OpenFOAM Bugs | 2 | January 12, 2010 05:10 |
| SegFault due to illegal readwrites | msg30 | OpenFOAM Bugs | 4 | December 12, 2007 12:44 |
