-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   Continue from previous log file (http://www.cfd-online.com/Forums/openfoam/80265-continue-previous-log-file.html)
bernarde September 21, 2010 05:09
Hi all
I am look for a way to continue from my previous log file. Suppose I run a simulation for 2000 iteratins, using for example simpleFoam > log.
The simulation completes, and now I want to run for an additional 1000 iterations. Is there a way I can add these iterations to the first log file, or do I have to create an additional log file? If I run simpleFoam > log again, it overwrites the original log file, and the new one is only from iteration 2000 to 3000. I can do simpleFoam > log2, but then I have two logfiles, and I have to combine them to view residuals etc.
Is there a command to have the original log file appended with the new run data?
Regards
l_r_mcglashan September 21, 2010 05:19
Use:
instead of
Test it though to be sure...
bernarde September 21, 2010 08:06
Thanks Laurence, that worked perfectly.
