September 24, 2010, 12:34 |
turbDyMFoam and Convergence
Robert
I have used icoDyMFoam to run a turbomachinery case (I was learning to use OpenFOAM, mesh, etc.), and obviously it did not converge. So I have been trying to implement turbDyMFoam. I have downloaded the files found here: http://openfoamwiki.net/index.php/Si...vaned_diffuser And transplanted the controlDict, RASProperties, transportProperties, fvsolution, and fvscheme files to my (originally icoDyMFoam) case. I also put boundary conditions on the inlet (freestream) flow (I am doing an external flow with a rotating part) for k and epsilon (zerogradient for everywhere else). The simulation runs at least, but soon diverges (floating point exception, huge velocity magnitudes). Can anybody give me a guide to the parameters I can adjust to get convergence? Thanks in advance. |
September 24, 2010, 15:17 |
Robert
I get these figures:
Largest slave weighting factor correction : 1.0817671 average: 1.0000028 Largest master weighting factor correction: 1 average: 1 It is actually running, and I am only getting floating point exceptions, so I guess that means only the initial conditions are bad. I have tried: http://www.cfd-online.com/Forums/ope...implefoam.html http://www.cfd-online.com/Forums/ope...ps-k-re-u.html None fail to diverge. Last edited by lordvon; September 24, 2010 at 16:54. |
September 24, 2010, 20:27 |
Robert
Hey guys,
Posting working cases of turbulent external flow using turbdymfoam would be highly appreciated. |
September 25, 2010, 07:13 |
Andrea Pasquali
Hi lordvon,
I'm trying turbDyMFoam with ggi on wind turbine analysis and it's working well. I use RAS kOmegaSST turbulence model. Have you good mesh (especially in nonOrthoFaces check)? Are your turbulent parameters internalField values correct? Regards
Andrea Pasquali |
September 25, 2010, 19:03 |
Robert
Hello Andrea, thanks for your reply.
I ran 'checkMesh' and it said that one mesh check failed. I could not discern what exactly this was from the terminal outputs. 'Non-orthogonality check OK.' ; is this what you were talking about? I posted the entirety of the terminal message below. I have also posted below my initial condition files for k and epsilon. I calculated them using the common formulas. The boundary types in those files are not the only ones I have tested. Could I take a look at your fvsolution, fvscheme, and /0/ files for k, epsilon, and omega? Have you tried using RNGkepsilon? /0/k: Code:
dimensions [0 2 -2 0 0 0 0]; internalField uniform 0.17; boundaryField { left { type zeroGradient; //type turbulentIntensityKineticEnergyInlet; //intensity 0.05; //value 1; } top { type zeroGradient; } right { type zeroGradient; } bottom { type zeroGradient; } outsideSlider { type ggi; } casing { type zeroGradient; } defaultFaces { type empty; } insideSlider { type ggi; } shaft { type zeroGradient; } blades { type zeroGradient; } } Code:
dimensions [0 2 -3 0 0 0 0]; internalField uniform .67; boundaryField { left { type zeroGradient; //type turbulentMixingLengthDissipationRateInlet; //mixingLength 0.1; //value uniform 200; } top { type zeroGradient; } right { type zeroGradient; } bottom { type zeroGradient; } outsideSlider { type ggi; } casing { type zeroGradient; } defaultFaces { type empty; } insideSlider { type ggi; } shaft { type zeroGradient; } blades { type zeroGradient; } } Code:
Create time --> FOAM Warning : From function dlLibraryTable::open(const fileName& functionLibName) in file db/dlLibraryTable/dlLibraryTable.C at line 86 could not load libOpenFoamTurbo.so: cannot open shared object file: No such file or directory Create polyMesh for time = constant Time = constant Mesh stats points: 72864 internal points: 0 faces: 248063 internal faces: 104627 cells: 70538 boundary patches: 10 point zones: 0 face zones: 2 cell zones: 2 Number of cells of each type: hexahedra: 0 prisms: 70538 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. *Number of regions: 2 The mesh has multiple regions which are not connected by any face. <<Writing region information to "constant/cellToRegion" Checking patch topology for multiply connected surfaces ... Patch Faces Points Surface topology left 37 76 ok (non-closed singly connected) top 56 114 ok (non-closed singly connected) right 37 76 ok (non-closed singly connected) bottom 56 114 ok (non-closed singly connected) outsideSlider 456 912 ok (non-closed singly connected) casing 670 1340 ok (non-closed singly connected) defaultFaces 141076 72864 ok (non-closed singly connected) insideSlider 456 912 ok (non-closed singly connected) shaft 16 32 ok (non-closed singly connected) blades 576 1152 ok (non-closed singly connected) Checking geometry... This is a 2-D mesh Overall domain bounding box (-1.125 -1.125 0) (2.25 1.125 1) Mesh (non-empty) directions (1 1 0) Mesh (non-empty, non-wedge) dimensions 2 All edges aligned with or perpendicular to non-empty directions. Boundary openness (-1.6291944e-17 -4.3115768e-17 -1.895701e-23) Threshold = 1e-06 OK. ***High aspect ratio cells found, Max aspect ratio: 3898.0533, number of cells 37146 Threshold = 1000 <<Writing 37146 cells with high aspect ratio to set highAspectRatioCells Minumum face area = 2.5918065e-07. Maximum face area = 0.084123393. Face area magnitudes OK. Min volume = 2.5918065e-07. Max volume = 0.0027079637. Total volume = 7.5688711. Cell volumes OK. Mesh non-orthogonality Max: 33.073843 average: 6.9423388 Threshold = 70 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.49352535 OK. Failed 1 mesh checks. End |
September 25, 2010, 21:18 |
fvSolution tolerance and reltol
Robert
Hello everyone,
Running komegaSST, I no longer get floating point exceptions (at least not yet). However looking at the output through paraFoam, things are still crazy. I stumbled upon this thread: http://www.cfd-online.com/Forums/ope...timesteps.html , I started to increase tolerance of p's reltol. That decreased the amount of bounding messages, though they still appear. So I was wondering, can anybody explain how to adjust the fields in fvSolution (preconditioner, tolerance, reltol) to get better convergence and accuracy? Here is a relative section in the OpenFOAM manual: http://www.openfoam.com/docs/user/fvSolution.php (I am looking into it myself of course, I put this up so that a solution may be worked towards in parallel) ADDITIONS: Ok, so I have decided to set all 'reltol's to zero, that way we only have to worry about the 'tolerance'. Do I need to mess with the preconditioners? My system files so far: fvSolution: Code:
solvers { pcorr PCG { preconditioner DIC; tolerance 1e-10; relTol 0; }; p PCG { preconditioner DIC; tolerance 1e-10; relTol 0; }; pFinal PCG { preconditioner DIC; tolerance 1e-10; relTol 0; }; U PBiCG { preconditioner DILU; tolerance 1e-10; relTol 0; }; k PBiCG { preconditioner DILU; tolerance 1e-10; relTol 0; }; epsilon PBiCG { preconditioner DILU; tolerance 1e-10; relTol 0; }; R PBiCG { preconditioner DILU; tolerance 1e-10; relTol 0; }; omega PBiCG { preconditioner DILU; tolerance 1e-10; relTol 0; }; } PISO { nCorrectors 3; nNonOrthogonalCorrectors 1; pRefCell 0; pRefValue 0; } Code:
ddtSchemes { default Euler; } gradSchemes { default Gauss linear; grad(p) Gauss linear; grad(U) Gauss linear; } divSchemes { default none; div(phi,U) Gauss upwind; div(phi,k) Gauss upwind; div(phi,epsilon) Gauss upwind; div(phi,omega) Gauss upwind; div(phi,R) Gauss upwind; div(R) Gauss linear; div(phi,nuTilda) Gauss upwind; div((nuEff*dev(grad(U).T()))) Gauss linear; } laplacianSchemes { default none; laplacian(nuEff,U) Gauss linear corrected; laplacian((1|A(U)),p) Gauss linear corrected; laplacian(DkEff,k) Gauss linear corrected; laplacian(DepsilonEff,epsilon) Gauss linear corrected; laplacian(DREff,R) Gauss linear corrected; laplacian(DnuTildaEff,nuTilda) Gauss linear corrected; laplacian(DomegaEff,omega) Gauss linear corrected; laplacian((rho*(1|A(U))),p) Gauss linear corrected; laplacian(alphaEff,h) Gauss linear corrected; laplacian(rAU,p) Gauss linear corrected; laplacian(nu,U) Gauss linear corrected; laplacian(1,p) Gauss linear corrected; } interpolationSchemes { default linear; interpolate(U) linear; } snGradSchemes { default corrected; } fluxRequired { default no; p; } Last edited by lordvon; September 25, 2010 at 21:51. |
