multiHoleInjector
Like Tree3Likes
  • 3 Post By niklas
Old   September 25, 2010, 09:39
Default multiHoleInjector
fairus
mfmohdyasin is on a distinguished road
Dear all,
Does anyone know what xyAngle, zAngle and umbrellaAngle in multiHoleInjectorProps dictionary below mean?
Is the 'direction' not required? Then how the injection direction is determined?
position (0.0097 0.028 0.01);
xyAngle 0;
zAngle 180.0;
nHoles 4;
umbrellaAngle 120.0;
nozzleTipDiameter 1e-3;
angleSpacing
0.0
22.5
22.5
20.0
Thanks in advance,
Fairus
mfmohdyasin is offline   Reply With Quote
Old   September 25, 2010, 15:46
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
http://openfoamwiki.net/index.php/Co...ctorProperties
The direction of the injecor is defined via the xy and z angles.
The spray is injected around this direction with the umbrellaAngle
spread around the full circle with the angleSpacing angles
niklas is offline   Reply With Quote
Old   September 26, 2010, 07:53
fairus
Niklas,
Thanks for the reply.
I would like to set the injection direction to be in +z direction. With unitInjector, I will set: direction (0 0 1);
How can I do the same with multiHoleInjector? I can set zAngle = 0, but I've to specify a value for xyAngle, which makes the direction to be not purely in +z direction.
One more, Is there any relationship between umbrellaAngle and innerConeAngle/outerConeAngle which is in the hollowConeInjectorCoeffs dictionary? Graphical explanation will be highly appreciated.
Best,
Fairus
Old   September 26, 2010, 09:09
niklas's Avatar
Niklas Nordin
if you set zAngle to 0 (or 180) the value of xyAngle wont matter.
The umbrellaAngle is the angle between the individual sprays along the injector-direction.
The inner/outer cone angles are the angles of an individual spray.
angleSpacing is the angles between the spray centerlines in the plane perpendicular to the injector-direction.
Old   September 27, 2010, 13:45
X.G. Li
CYMa is on a distinguished road
Hallo, Niklas
I use the rhoPisoTwinParcelFoam to investigate a particle-laden gas flow.
I want to calculate the total particle number across a cell surface in certain time.
And then I can get a particle flux for this cell face by N/(t*A),
N, the total particle number across the cell surface;
t, time;
A, cell surface area.
I have poor knowledge about C++.
May you give me some help?
Thank you very much!
CYMa is offline   Reply With Quote
Old   September 27, 2010, 15:48
niklas's Avatar
Niklas Nordin
Originally Posted by CYMa View Post
Hallo, Niklas
t, time;
hijacking threads makes Niklas sad and wont give you an answer
Rickard.Solsjo, kmpang and novakm like this.
