August 22, 2013, 12:04 |
#21 |
India
Rep Power: 13 |
I found answers to all my queries. Below thread was really helpful:
http://www.cfd-online.com/Forums/ope...r-airfoil.html Thanks Yogesh for providing a hint. Cheers, Mayank |
August 27, 2013, 16:26 |
#22 |
India
Rep Power: 13 |
Hi Yogesh,
Sorry to disturb you again. Now, I am trying to calculate deposition of particles on tube wall. So what changes should I make to 'localInteractionCoeffs' such the particle sticks to the wall as soon as it touches it and also want to count those. Regards, Mayank. |
August 28, 2013, 00:23 |
#23 |
Yogesh Bapat
Rep Power: 15 |
Hello ,
For 'wall' write in localInteraction wall { type stick; } Regards, -Yogesh |
August 29, 2013, 15:37 |
#24 |
India
Rep Power: 13 |
I have a problem and I am trying for many days. I am doing one way coupled(in a bifurcating tube with one inlet and two outlets) simulation using icoUncoupledKinematicParcelFoam with pre-defined steady state velocity field . Diameter of INLET is 6mm and that of OUTLET1 is 4mm and OUTLET2 is 6mm. I am injecting 10,000 spherical particles of 0.6mm diameter the ratio of particles coming out of OUTLET2 to OUTLET 1 should be close to 1 but I am getting way higher particle ratios. I have tried mesh refinement, ratio are getting worse. I have tried changing the fluid, initial particle velocities and steady state fluid velocity field and nothing helps! Please anybody can comment and give an idea for changing things. Same simulation done on CFX and fluent yield satisfactory results. Regards, Mayank |
September 4, 2013, 11:45 |
#25 |
India
Rep Power: 13 |
1.) In 'kinematicCloudProperties' what does below means: 'coupled true/false;' what difference will true or false make? 2.) I want to give initial particle velocity same as the velocity of fluid? How can this be done, since my inlet velocity profile is a fully developed parabolic one for fluid phase and I want particles to follow the same profile that is at inlet? The option available for specifying initial velocity in 'kinematicCloudProperties' file is: U0 (0 0 0); // it will take only uniform velocity profile Can groovy expression be used here? Regards, Mayank Last edited by mayank.dce2k7; September 4, 2013 at 13:21. |
September 9, 2013, 18:32 |
#26 |
India
Rep Power: 13 |
Hi Foamers,
How can I give 'U0' (in kinematicParticleProperties) in form of a table specifying each particle's velocity ? Regards, Mayank. |
April 30, 2014, 09:19 |
Particle inlet velocity
#27 |
Rep Power: 12 |
Hi Mayank,
Did you find the answer to your question? I'm struggling with the same problem. Best regards rafab |
April 30, 2014, 13:21 |
#28 |
India
Rep Power: 13 |
I guess you are referring to this question: How can I give 'U0' (in kinematicParticleProperties) in form of a table specifying each particle's velocity ? You can use KinematicLookupTableInjection...here you can specify properties of each particle. Regards, Mayank. |
April 30, 2014, 13:37 |
#29 |
Rep Power: 12 |
Yes, that's exactly what I asked about and what I need.
Thanks a lot. It will help me a lot Cheers rafab |
May 28, 2015, 09:22 |
#30 | |
Alaska1964
Rep Power: 10 |
Dear Mayank, Did you find answer for your problem? I have the same problem. I am simulating droplets in a L shape channel. I am using the following conditions: patchInteractionModel localInteraction; localInteractionCoeffs { patches ( WALL { type rebound; e 1; mu 0.9; } ); } In my log file it is reported that: Parcel fate (number, mass) : patch WALL - escape = 0, 0 - stick = 0, 0 I want to count the number of droplets deposited on the wall. Ho can Count it ? Shall I add a specific command in kinematicCloudProperties to show the number of droplets deposited? Cheers, Last edited by Alaska1964; May 29, 2015 at 03:57. |
December 23, 2015, 07:14 |
Calculation of particle deposition
#31 |
Subhasree
Rep Power: 12 |
Hi Everyone!
i have used icoLagrangianFoam to simulate a 3-D flow over an object. Can anybody tell me how may I calculate or plot the number of particles deposited on the object? |
January 4, 2016, 01:17 |
Number of Particle Deposition
#32 |
Subhasree
Rep Power: 12 |
Hi Everyone!,
Can anybody suggest me how can I calculate the number of particle deposition on an object? I am using icoLagrangianFoam solver in foam extend-3.1 |
January 9, 2016, 15:12 |
#33 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
Subhasree and Alaska1964: Can either one of you provide more details of how exactly the particles are deposited in the object's surface? More specifically, is there a small tutorial case I can look at (and test with) to see and study this effect? I ask this because if the particle is "frozen" on the wall surface, then it's possible to create a counter that counts the number of particles that are frozen on a particular patch. AFAIK, OpenFOAM and foam-extend don't have yet such a utility, but it should be simple enough to do, based on the already existing utilities that OpenFOAM/foam-extend have got. Then again, swak4Foam might already have something for this... Best regards, Bruno
January 11, 2016, 03:48 |
#34 |
Subhasree
Rep Power: 12 |
Thanks a lot Bruno,
Actually I could not find any tutorial as such, on particle deposition or icoLagrangianFoam solver. I have used option 'stick' on the object wall instead of 'frozen'. Also, according to some of the online blogs this should give me a counter of the number of particles that are stuck and number that escaped on residual terminal..but I am not very sure of this. I was basically looking if there is a way to post-process using paraFoam to show the number of particles deposition. |
February 8, 2016, 23:37 |
Particle Deposition
#35 |
Subhasree
Rep Power: 12 |
I am simulating 3-D particle flow over an object using icoLagrangianFoam solver and would like to find the number of particles deposited on the object. I have used keyword "stick" in LocalInteractionCoeffs of kinematiccloudProperties but after simualtion is complete it is not showing the number of deposited particle. Please Help!!! |
February 20, 2016, 01:17 |
#36 |
Subhasree
Rep Power: 12 |
Hi everyone,
I am working on particle deposition on a surface using icoLagrangianFoam solver. I have meshed a .stl file using snappyHexMesh and then simulated it. Although my simulation was running fine and showing the particle deposition in the post-processing file it is not moving forward after 10.95 sec. I think its getting stuck there. It is not showing any error message in the residual log file. System is showing it is running the solver but it is not moving after 10.95 sec. I am running the simulation in parallel processor. I am attaching an image of the log file. Can anyone suggest how may I proceed to solve this problem? I have checked the mesh using checkMesh, and it not showing any error. |
February 22, 2016, 10:09 |
#37 |
Alaska1964
Rep Power: 10 |
Dear All,
Thank you for your interest to help in advance. My problem is solved. I have changed the particle wall interaction to patch wall stick which means particles will deposit on the wall once they touch it. In this case there is no problem, I get the number of sticked particles in the log file. Best regards, Alaska |
March 30, 2016, 07:51 |
#38 |
ksengupta
Rep Power: 16 |
You can use cloudFunctions in constant/kinematicCloudProperties. Use like this.
cloudFunctions { patchPostProcessing1 { type patchPostProcessing; maxStoredParcels 1e07; patches ( outlet ); } } |
April 1, 2016, 10:22 |
Number of particles in each cell
#39 |
HM
Rep Power: 11 |
Hi foamers,
I am using solidParticle class and I am trying to calculate the number of particles in each cell at certain times. I want to combine all of the particles in a cell. Any suggestions? Thanks, |
May 12, 2016, 22:55 |
#40 |
Ping Chang
Rep Power: 10 |
Have you found the solution for your question? I met the same question as you .
mesh file for flow over a circular cylinder | Ardalan | Main CFD Forum | 7 | December 15, 2020 13:06 |
Problem with decomposePar tool | vinz | OpenFOAM Pre-Processing | 18 | January 26, 2011 02:17 |
Particle Tracking | Batis | CFX | 2 | October 6, 2010 15:20 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
particle courant number | Michiel | Siemens | 1 | August 10, 2003 05:50 |
