September 30, 2010, 14:56 |
Turbulent BCs: Wall Functions
Robert
Rep Power: 15 |
Should k and omega for komegasst turbulence model be fixed at walls or zerogradient? From the forums I have seen zerogradient, but here: http://repo.or.cz/w/OpenFOAM-1.6.x.g...am/motorBike/0 , I see fixed. |
October 1, 2010, 04:11 |
Felix L.
Rep Power: 18 |
Hi, there,
when using the k-Omega-SST turbulence model in OpenFOAM, you have to use the boundary conditions kqRWallFunction and omegaWallFunction for k and omega, respective. The reason is that the implementation of k-Omega-SST in OpenFOAM is the High-Re-version, which requires a wall function approach. When specifying a wall function BC, you also have to set a value (as you saw in the motorBike-tutorial case). Set it to the initial values you used for your internal Fields of k and omega, since - to my knowledge and experience - it won't affect your solution. The wall functions automatically take care for the value at the wall. Greetings. |
October 1, 2010, 10:45 |
Robert
Rep Power: 15 |
Is that supposed to be so in OF1.5-dev?
I have set in the /0/omega file the walls to be of type omegaWallFunction, with value $internalField, but I get this error: Code:
generic is the wrong omega patchField type for wall-functions on patch casing should be zeroGradient If I set the wall to be of type zeroGradient, I do not get an error, but the simulation eventually diverges. Should I add an (initial) value along with the zerogradient type (Is it even legal)? It does not give a problem if I do so, but is the value being ignored? Thanks for your help. |
October 1, 2010, 12:43 |
Robert
Rep Power: 15 |
Also I am trying to ramp up the rpm using a logistic function; does anyone know how I can get the current rpm to print in the terminal so I know it is working?
Is it ok if the very first frame looks crazy in terms of pressure distribution (rotating object in external flow)? Will sharp edges in the rotating part or small gaps between rotor and stator affect convergence? |
October 1, 2010, 14:26 |
Robert
Rep Power: 15 |
Here is something that confuses me:
http://repo.or.cz/w/OpenFOAM-1.6.x.g...incompressible The simpleSRFFoam and simplefoam/motorbike examples both use komegasst, but the srffoam has epsilon and omega both defined in the 0/ directory, but motorbike has only omega and in the omega file it says it is an 'epsilon' object. Why the difference? |
Display Modes | |
Modelling Turbulent Wall Functions | victorwfreire | CFX | 11 | January 14, 2015 15:48 |
help with wall functions | dshawul | Main CFD Forum | 6 | May 23, 2011 03:12 |
wall functions near slanting wall | Pankaj | Main CFD Forum | 0 | September 11, 2008 09:50 |
LES - Wall Functions | agg | Main CFD Forum | 5 | May 13, 2005 12:30 |
Wall functions - iterative approach | agg | Main CFD Forum | 1 | May 13, 2005 12:25 |
