rhoSimpleFoam
Old   September 30, 2010, 06:34
Default rhoSimpleFoam
green is on a distinguished road
Hello
i wanted to start a case with openSimpleFoam of channel (30m/s and 293K) with secondary inlet (70m/s and 348K), but something is wrong because after a first iteration the density is far from realistic value (rho max/min : 7.62292 -65.1773) and then after third iterations i get an error:
Maximum number of iterations exceeded#0 Foam::error:rintStack(Foam::Ostream&) in "/home/user/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/user/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Foam::hPsiThermo<Foam:ureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > >::calculate() in "/home/user/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libbasicThermophysicalModels.so"
#3 Foam::hPsiThermo<Foam:ureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > >::correct() in "/home/user/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libbasicThermophysicalModels.so"
#4 main in "/home/user/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/rhoSimpleFoam"
#5 __libc_start_main in "/lib/libc.so.6"
#6 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/i386/elf/start.S:122
From function specieThermo<thermo>::T(scalar f, scalar T0, scalar (specieThermo<thermo>::*F)(const scalar) const, scalar (specieThermo<thermo>::*dFdT)(const scalar) const) const
in file /home/dm2/henry/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/specie/lnInclude/specieThermoI.H at line 68.
FOAM aborting
Could it bee something the the path (red collor) is not existing on my computer?
Any suggestions?
Thanks
green is offline   Reply With Quote
Old   October 1, 2010, 11:32
Default deltaT
T.D. is on a distinguished road
hi
did you tried to decrease your deltaT
T.D. is offline   Reply With Quote
Old   October 1, 2010, 11:56
Default rhoSimpleFoam to rhoPisoFoam
i tried also with smaller deltaT and I figured also that i have to correct the epsilon boundary and initial values but the solution with rhoSimpleFoam doesnt work it stops with same error but after 6 iteration instead of 4.
I solved the problem with use of rhoPisoFoam solver.
Thanks for your reply
transsonic nozzle with rhoSimpleFoam Unseen OpenFOAM Running, Solving & CFD 8 July 1, 2022 06:54
Dimesion error after switching from simpleFoam to rhoSimpleFoam sebastian OpenFOAM Bugs 2 June 17, 2010 08:03
Question about rhoSimpleFoam "if (transonic)" universez OpenFOAM 4 April 17, 2010 10:21
Problem with rhoSimpleFoam mecbe2002 OpenFOAM 3 April 11, 2010 00:54
Stability startup problems with rhoSimpleFoam olesen OpenFOAM Running, Solving & CFD 1 July 18, 2006 08:09
