Home > Forums > OpenFOAM
GGI Interface Partially Against a Wall
Old   October 2, 2010, 09:34
Default GGI Interface Partially Against a Wall
lordvon is on a distinguished road
Suppose we take the mixerGgi tutorial case (closed; outer wall and rotating mesh boundary are concentric) and introduce a few openings in the outer wall for inlets and outlets, and also enlarge the fan blades so that there is a small gap between the tip of the blades and the outer wall.
Is it possible to extend the rotating mesh boundary all the way to the outer wall (then the only stator mesh remaining would be that of the inlets and outlets), and would any advantage be gained in this setup?
lordvon is offline   Reply With Quote
Old   October 3, 2010, 19:45
Masashi Ohbuchi
Ohbuchi is on a distinguished road
If you extend the rotating mesh boundary(GGI interface?) all the way to the outer wall,
whole domain other than its inlet and/or outlet opening boundary would be rotating.
So it would be suitable MRF simulation, but if you treat outer wall as counter-rotating wall, inlet and/or boundary on the outer wall should be rotating.
Can we handle these rotating region by use of partial overlap Ggi?
Ohbuchi is offline   Reply With Quote
Old   October 6, 2010, 08:21
Hrvoje Jasak
You should use the sliding interface for this: it will geometrically split the patch and allow you to specify the boundary condition on the exposed part in the usual way.
Hrvoje Jasak
Providing commercial FOAM/OpenFOAM and CFD Consulting:
Thread Tools
Trackbacks are On
source code for GGI interface rcm OpenFOAM 1 May 5, 2010 10:49
Defining Interface as wall Hectux OpenFOAM Running, Solving & CFD 6 June 8, 2009 04:45
No results for solid domain Gary Holland CFX 10 March 13, 2009 04:30
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
Wall function in adverse pressure gradients stephane baralon Main CFD Forum 11 September 2, 1999 04:05
