Home > Forums > OpenFOAM
Apparent inviscid flow over rectangle problems
Old   October 4, 2010, 14:58
Default Apparent inviscid flow over rectangle problems
jeff osborne
ozzythewise is on a distinguished road
Hi all,
I'm simulating flow over a rectangle at a Reynolds number of 10^5, using upwind discretization scheme, komega turbulent model, water at 20 degrees C as the fluid. I'm expecting to see recirculation just behind the leading edge of the rectangle but I can't see it. Attached is a picture of my stream lines. I'm using a grid set up such that I have a y+ of ~5. From my picture you can see that it looks like my simulation is completely inviscid, which makes no sense to me. Anyone have any ideas?
Thanks
-J
ozzythewise is offline   Reply With Quote
Old   October 5, 2010, 16:54
jeff osborne
Does anyone have an idea for this?
Thanks
-J
Old   October 6, 2010, 07:47
jeff osborne
If anyone has any ideas for this I would really appreciate it, I am really stuck on this one. I think the issue is with my wall functions, but I really don't know. Here is my 0/nut file:
dimensions [0 2 -1 0 0 0 0];
internalField uniform 0;
boundaryField
inlet
type fixedValue;
value uniform 0;
outlet
type zeroGradient;
topAndBottom
type symmetryPlane;
rectangle
type nutWallFunction;
value uniform 0;
frontAndBack
type empty;
Does anyone have any ideas to help me out?
Thanks
-Jeff
Old   October 6, 2010, 08:34
maddalena's Avatar
maddalena
maddalena is on a distinguished road
Hi Jeff,
how do you define your rectangle patch in constant/polymesh/boundary? it should be wall.
And what about k and omega values? they should be kqRWallFunction and omegaWallFunction.
One more check: what OF version are you using?
hope it helps.
regards
mad
maddalena is offline   Reply With Quote
Old   October 6, 2010, 08:43
jeff osborne
Hi mad,
My rectangle patch is defined as a wall, and I am using the kqRWallFucntion and omegaWallFunction for k and omega respectively. I'm using OF v1.6. Any other thoughts?
-J
Old   October 6, 2010, 09:08
jeff osborne
Here's another noodle scratcher;
If I plot my wall shear stress at my last time step on the wall (close to the leading edge, x~10% down the wall) I get a value of about 1.8e-5. If however I plot my velocity gradients at the same location, I get a value of 12.5, which if I multiple it by the dynamic viscosity (in this case it's 0.001) I get a wall shear stress value (cause tau_wall = mu * wallGrad) I get a wall shear stress of 0.0125, which doesn't at all match up with 1.8e-5. Can anyone make anything of this?
-Jeff
Thread Tools
Trackbacks are On
What solver to use for inviscid flow simulation over missile mecbe2002 OpenFOAM 0 April 27, 2010 11:10
SIMPLE method for inviscid flow abcdef123 Main CFD Forum 0 February 26, 2010 09:24
Nozzle flow simulation in inviscid and viscous Cath FLUENT 0 January 28, 2007 03:16
Problems at transonic flow Mario FLUENT 0 September 26, 2005 05:27
High speed flow problems Sawa FLUENT 3 January 14, 2003 02:10
