January 4, 2017, 06:10 |
where's the singleGraph output?
Kama Kashkanov
I need output for the alpha.water field along a line, to understand I did the singleGraph tutorial: http://cfd.direct/openfoam/user-guid...hs-monitoring/ chapter 6.3.2 It uses the pitzDaily case. So I copied pitzDaily into run, ran blockMesh and simpleFoam on it, made sure it worked with paraView. Then I copied the singleGraph file from FOAM_ETC to system. I edited singleGraph and controlDict as I was told. I ran simpleFoam with and without postProcess option, but I can't find any output in pitzDaily/postProcessing - there's not even a directory called singleGraph. singleGraph Code:
\*---------------------------------------------------------------------------*/ start (0.01 0.025 0); end (0.01 0.025 0); fields (U p); // Sampling and I/O settings #includeEtc "caseDicts/postProcessing/graphs/sampleDict.cfg" // Override settings here, e.g. // setConfig { type midPoint; } // Must be last entry #includeEtc "caseDicts/postProcessing/graphs/graph.cfg" // ************************************************************************* // Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application simpleFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 2000; deltaT 1; writeControl timeStep; writeInterval 100; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; functions { #includeFunc streamlines #includeFunc singleGraph } // ************************************************************************* Thanks in advance. |
January 4, 2017, 06:17 |
dunno just did it again
Kama Kashkanov
and it worked.
sorry. thread can be closed now, can i do that somewhere? |
simplefoam, singlegraph |
[swak4Foam] outputTime in Swak function | immortality | OpenFOAM Community Contributions | 20 | October 6, 2022 12:08 |
writing execFlowFunctionObjects | immortality | OpenFOAM Post-Processing | 30 | September 15, 2013 06:16 |
RNG diverged during the analysis the flow over a multi element airfoil, why? | s.m | OpenFOAM Running, Solving & CFD | 0 | August 5, 2013 08:39 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 09:34 |
lift and drag on ship superstructures | vaina74 | OpenFOAM Running, Solving & CFD | 3 | June 8, 2010 12:30 |
