-   OpenFOAM (https://www.cfd-online.com/Forums/openfoam/)
-   -   Non equilibrium wall function : pressure acquisition problem (https://www.cfd-online.com/Forums/openfoam/80799-non-equilibrium-wall-function-pressure-acquisition-problem.html)
MafioTia October 6, 2010 18:52
Hi everyone.
I'm trying to implement a fluent-type wall function sensitized to pressure gradient, i.e. "non-equilibrium WF". There is no problem in epsilon/omega WF when I get the pressure gradient, needed for my calculation, in this way:
const volScalarField& P = db().lookupObject<volScalarField>("p");
volVectorField grdntP = fvc::grad(P);
If I apply the same procedure in nutSpalartAllmarasWF ( that follows the general Spalding law-of-the-wall but it has to be sentivized to pressure gradient, too!) the solution explode in an unexplainable way. I've already tried to debug my code on every line that I added and I've concluded that the problematic line is the second I wrote before.
My idea is that this procedure applied to nut-WF result in an unintentional modify of the pressure field, but I thin it's a weak idea, if I had understood OF works.
Any idea?
maolongliu October 10, 2010 04:45
Hi, have you solved this problem?
I am now also trying to write a new wall function including pressure gradient.
Originally Posted by MafioTia (Post 278181)
Hi everyone.
Any idea?
