October 4, 2010, 13:20 |
refernces interFoam
Rep Power: 16 |
does anyone have a reference list with scientific publications relating to interFoam or/and OpenFoam? I found a whole bunch of conference papers, countless presentations, and a few PhD-thesis, but I'm rather looking for peer-reviewed papers in journals or books. I also found the list on Prof. Jasak homepage http://www.h.jasak.dial.pipex.com/index.html, but it would be nice to have more. Kindest regards! |
October 5, 2010, 11:47 |
Lars Kiewidt
Rep Power: 16 |
recently I found some publications about interFoam. At first I would recommend Henrik Rusche's Ph.D. Thesis. You can find it on http://powerlab.fsb.hr/ped/kturbo/OpenFOAM/docs/ . Chapter 4 is mainly about interFoam. Prof. Jasak's Ph.D. Thesis from the same website is about OpenFOAM in general and the FVM method. Then I read some of these papers. The last one is a textbook. [1] Brackbill et al.: A Continuum Method for Modeling Surface Tension. J. Comput. Phys. 100 (1992), pp. 335-354 [2] Gopala, Wachem: Volume of fluid methods for immiscible-fluid and free-surface flows. Chem. Engineering Journal 141 (2008), pp. 204-221 [3] Versteeg, Malalasekera: An Introduction to Computational Fluid Dynamics, The Finite Volume Mehtod. Pearson (2007), 2nd Edition I hope this will help you for the moment! Lars |
October 6, 2010, 08:32 |
Rep Power: 16 |
Thanks Lars!
In my opinion the Versteeg and Malalasekera book is one of the best CFD-FVM books and the papers are also quite good, but I have already understood more or less the used techniques and there is no lack of scienfic papers, that relate to the used methhods. Hence, I'm personally already convinced of the capabilities of interFoam/ OpenFoam. I just need some publications, that bring interFoam/ openFoam, let´s call it, in "scientific context". |
October 6, 2010, 11:51 |
Lars Kiewidt
Rep Power: 16 |
Oh, I'm sorry! You are looking for some papers and scientific work where OpenFOAM/interFaom is used to simulate different problems.
I don't know in which field you are working but if you have a look at www.sciencedirect.com and type 'OpenFOAM' in the search function, you will find round about 100 papers. Some of some are about numerical methods, some just used OpenFOAM. Best regards, Lars |
October 6, 2010, 15:37 |
Santiago Marquez Damian
Rep Power: 23 |
Friedrich, the best paper to date about interFoam is the one from Edin Berberovic,
http://pre.aps.org/abstract/PRE/v79/i3/e036306 Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D. Research Scientist Research Center for Computational Methods (CIMEC) - CONICET/UNL Tel: 54-342-4511594 Int. 7032 Colectora Ruta Nac. 168 / Paraje El Pozo (3000) Santa Fe - Argentina. http://www.cimec.org.ar |
October 6, 2010, 17:01 |
Rep Power: 16 |
Thanks Santiago, I ordered it and will check it asap.
October 10, 2010, 11:51 |
Claus Meister
Rep Power: 17 |
Hallo FG_HSRM,
when you will have got that paper could you sent it to me copy, please? Cheers |
interFoam / bubbleFoam to simulate an aerated tank | Meratb | OpenFOAM Running, Solving & CFD | 3 | November 6, 2020 11:45 |
InterFoam stops after deltaT goes to 1e14 | francesco_b | OpenFOAM Running, Solving & CFD | 9 | July 25, 2020 06:36 |
Interfoam... free surface simulation urgent | lostin4ever | Main CFD Forum | 4 | October 12, 2010 08:29 |
Latest git 1.6.x: Crash when using inletOutlet for variable alpha1 in interFoam | carsten | OpenFOAM Bugs | 6 | September 23, 2009 09:46 |
Open Channel Flow using InterFoam type solver | sxhdhi | OpenFOAM Running, Solving & CFD | 3 | May 5, 2009 21:58 |
