Programmig own limiter function, modifying r function in limitedLinear.H
Old   October 12, 2010, 02:17
Default Programmig own limiter function, modifying r function in limitedLinear.H
Claus Meister
idrama is on a distinguished road
Hello Foamers,
I copied limitedLinear directory to somewhere else where I have modified some entries (for test purposes). Now, I want to compiled it and to integrate it into OpenFOAM: How do I have to proceed? Cany anyone advice me, please?
Cheers in advance
idrama is offline   Reply With Quote
Old   October 13, 2010, 16:06
Default wmake libso
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
I would probably try the following:
1. Create a Make directory in your folder containing the code you want to compile
2. create the "files" and "options" files and fill them appropriately for compilation of a shared object library
2.a files should have the name of your C file on the first line and the line LIB=$(FOAM_LIBBIN)/lib<your C file name without .C>
2.b the options file should have
EXE_INC= -I<any included files you need here>
LIB_LIBS = -l<any other libraries you need here>
3. then outside of your make folder, call wmake libso and it should compile
4. In the controlDict file of the case you want to use your new scheme, you add the line
libs("libSharedObject.so") where the words sharedobject is the name from 2.a
I hope this helps.
Dan
chegdan is offline   Reply With Quote
Old   October 14, 2010, 04:20
Claus Meister
Thank you very much! I got it.
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 04:37
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 00:35
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
