Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
A strange Problem with my OpenFoam animation
Old   August 4, 2015, 20:52
Default A strange Problem with my OpenFoam animation
Mike
saeedi is on a distinguished road
Hi there,
I am new to OpenFoam and just started working with that.
I have conducted a test on a 2D cylinder at Re=100 (laminar), just to make sure that the basics of my openfoam simulation are OK.
The simulation went well and I also made an animation for the flow evolution which can be downloaded from here:
https://www.dropbox.com/s/zqnvxg7hbt...-SLOW.avi?dl=0
and here is with the vectors superimposed:
https://www.dropbox.com/s/e3mvvvxnm0...ector.avi?dl=0
There is some thing that puzzles me a bit. Although it is quite obvious from the contour structures and topology that the flow is from left to right, in the animation it seems that those high U contours are begin convected from the outflow boundary to the cylinder. It is not a visual mistake as I refined the time step and got the same result.
I suspect there might be some more subtleties related to OpenFoam. I checked whatever I knew but could not find the problem. If I ran the animation in the reverse order then it looks quite nice!
if you look at the flow development, from time=0 to the first couple of snapshots, it shows that the flow is developing correctly and I think that is an indication that the zone order is right. But suddenly we see that reverse behavior around time=1.
I'd appreciate your help.
saeedi is offline   Reply With Quote
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
strange problem with data seav OpenFOAM Running, Solving & CFD 0 April 11, 2014 05:01
Problem in fvMesh.C when using topological changes. OpenFoam 2-2-x Horacio Aguerre OpenFOAM Programming & Development 0 August 14, 2013 11:57
OpenFOAM 1.7.1 installation problem on Fedora 14 armonica OpenFOAM Installation 16 March 31, 2011 13:16
Anyone met this strange problem? Lee Siemens 1 June 7, 2005 03:15
