Two-phase Eulerian model for nucleate subcooled boiling
Like Tree5Likes
  • 1 Post By Edy
  • 2 Post By yasin.ramzani
  • 2 Post By juho
Old   October 13, 2010, 11:56
Default Two-phase Eulerian model for nucleate subcooled boiling
Edy
Edy is on a distinguished road
Hi Foamers,
I want to model nucleate boiling using a Eulerian-Eulerian approach (no interface tracking or level set method but derivation of mass, momentum and energy conservation equations for both liquid and vapor phase).
Basically my geometry is a 2D semi-channel in the plane (x,y)
* x=0-axis corresponds to the centerline of the real channel (bulk coolant)
* x=xmax corresponds to the heated wall
* water is flowing along the y-axis
Physically speaking, part of the water will boil in the vicinity of the heated wall, and formed bubbles will subsequently move towards the center of the real channel, i.e towards x=0 and condensate due to the contact with the surrounding subcooled water. In this model, one assumes that the whole heat given by the wall is given to the liquid phase. The vapor phase can only gain energy through evaporation of water.
I started from the twoPhaseEulerFoam solver, and I implemented interfacial forces for drag, lift, virtual mass, turbulent dispersion, wall lubrication. In a first time, I just modeled the condensation of bubbles, assuming that at the inlet, there is some void and these bubbles are condensing while flowing along the channel. BUT FOR THE MOMENT NO HEAT WAS SUPPLY TO THE WALL, so no evaporation was considered. The results were quite satisfying.
Now i want to go one step further and add in my model the evaporation of water close to the wall. Before developing a more complicated boiling model, I tried something very simple. I just took a constant evaporation rate that I applied to the cells in contact with the wall. Then in my momentum and energy equations, I took into account both the variations due to condensation and evaporation, as well as the heat supplied by the wall to the liquid phase in contact with the wall.
However, my simulations crashed very quickly and I get this error message:
#0  Foam::error::printStack(Foam::Ostream&) in "/home/michta/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#1  Foam::sigFpe::sigFpeHandler(int) in "/home/michta/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#2   in "/lib/libc.so.6"
#3  Foam::LimitedScheme<double, Foam::limitedLinearLimiter<Foam::NVDTVD>, Foam::limitFuncs::magSqr>::limiter(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const in "/home/michta/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libfiniteVolume.so"
#4  Foam::limitedSurfaceInterpolationScheme<double>::weights(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const in "/home/michta/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libfiniteVolume.so"
#5  Foam::fv::gaussConvectionScheme<double>::fvmDiv(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&) const in "/home/michta/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libfiniteVolume.so"
 in "/home/michta/OpenFOAM/michta-1.7.x/applications/bin/linux64GccDPOpt/EulerEulerBoilingFoam"
#9  __libc_start_main in "/lib/libc.so.6"
Floating point exception
It seems that my velocity fields for both phases is diverging. My UEqn for the gas phase looks like that (similar for liquid phase):
        UaEqn =
            (scalar(1) + CVM*rhob*alpha*beta/rhoa)*
                fvm::ddt(Ua)
              + fvm::div(phia, Ua, "div(phia,Ua)")
              - fvm::Sp(fvc::div(phia), Ua)
          - fvm::laplacian(nuEffa, Ua)
          + fvc::div(Rca)
          + fvm::div(phiRa, Ua, "div(phia,Ua)")
          - fvm::Sp(fvc::div(phiRa), Ua)
          + (fvc::grad(alpha)/(fvc::average(alpha) + scalar(0.001)) & Rca)
        //  g                          // Buoyancy term transfered to p-equation
          - fvm::Sp(beta/rhoa*AD, Ua)
        //+ beta/rhoa*AD*Ub             // Explicit drag transfered to p-equation
          - beta/rhoa*(liftForce - virtualMassForcea + turbulentDispersionForce + wallLubricationForce)
          + (GammaGL-GammaLG)/(alpha+scalar(0.001))/rhoa*Ub
          - fvm::Sp((GammaGL-GammaLG)/(alpha+scalar(0.001))/rhoa, Ua)
Do you have any idea what could be wrong?
If you need more details, don't hesitate to ask.
Thanks in advance!
/Ed
Kummi likes this.
Edy is offline   Reply With Quote
Old   October 14, 2010, 21:51
J. Cai
chiven is on a distinguished road
Hi Edy, I am also doing the simulation on two-phase flow with phase change using Euler-Euler model. But you are way ahead of me. This time I am struggling at the stage without considering the mass and heat transfer.
Back to your question, I think you need to add a source term to the pressure equation considering the condensation or evaporation. Hope this can help you.
Best regards,
Chiven
chiven is offline   Reply With Quote
Old   October 15, 2010, 08:19
Edy
Hi Chiven,
Thanks for your reply.
Your answer is actually very helpful, i'll dig deeper in this p-Eqn and try to see which term to add. With condensation only, I kept the pEqn unchanged and it worked. But my evaporation rate is much bigger and it might cause some problems.
I'll check this issue next week cause I found out mistakes in my interfacial forces implementation that I need to solve first.
If you have questions while developing your model, dont hesitate to ask, perhaps I will have encountered the same problem before.
Thanks again.
Best
/Ed
Old   September 26, 2013, 12:31
yasin ramzani
yasin.ramzani is on a distinguished road
Originally Posted by Edy View Post
Hi Chiven,
Thanks again.
Best
/Ed
Hi
maybe its better to see master thesis of Edouard Michta (Modeling of Subcooled Nucleate Boiling with OpenFOAM)
Arjun Jayakumar and Kummi like this.
yasin.ramzani is offline   Reply With Quote
Old   February 9, 2017, 03:09
behzad Ghasemi
behzad-cfd is on a distinguished road
Originally Posted by yasin.ramzani View Post
Hi
Hi Mr.ramzani,
I've read that thesis and i think it's suitable for my work. But i couldn't find his solver on the net.
Do you have it? Or do you know how can i get it?
Thanks in advance,
behzad-cfd is offline   Reply With Quote
Old   February 11, 2017, 17:21
Juho Peltola
juho is on a distinguished road
It is not the Michta's solver discussed above, but you may wan't to look at reactingTwoPhaseEulerFoam of recent OpenFOAM releases (3.1 and newer).
You can currently find two subcooled nucleate boiling tutorials in OpenFOAM-dev:
Constant bubble diameter: https://github.com/OpenFOAM/OpenFOAM...AS/wallBoiling
With IATE diameterModel: https://github.com/OpenFOAM/OpenFOAM...allBoilingIATE
OpenFOAM2016 and Kummi like this.
juho is offline   Reply With Quote
Boiling and combustion of Eulerian phase? naimishharpal Main CFD Forum 0 August 29, 2010 20:13
Lift coefficients for Eulerian Multiphase Model Anastasios Georgoulas FLUENT 0 July 14, 2008 07:13
Source Term used in Eulerian Model(Two phase) Padian FLUENT 1 May 19, 2008 04:47
Mass and het transfer using eulerian model Pablo FLUENT 0 February 16, 2007 09:36
3 phase Eulerian Model krishna FLUENT 1 January 3, 2004 15:20
