Cdrag multiple tracking
Old   October 11, 2010, 08:26
Default Cdrag multiple tracking
Vesselin Krastev
vkrastev is on a distinguished road
Hi all,
I'm performing some aerodynamic calculations and it will be very useful to me to understand if by using the forceCoeffs function there is the possibility to track the drag coefficients of more than one patch at the same time (I mean during the same run). To be as much clear as I can, what I want to do is not to evaluate the Cdrag of an object composed by different patches, but namely the drag contribution of every single patch.
Thank you in advance
V.
vkrastev is offline   Reply With Quote
Old   October 12, 2010, 04:40
Vesselin Krastev
Any replies?
Old   October 12, 2010, 23:30
wei wu
wei_wu is on a distinguished road
I'd like to know the answers also.
wei_wu is offline   Reply With Quote
Old   October 13, 2010, 15:46
paka is on a distinguished road
Yes, it is mentioned in different posts. Search through the forum, I'm not sure I didn't use it for different patches, but I believe you just repeat the whole section where you call for force output, but you define multiple sections with different directory names. Something like:
name1
name2
I'm not sure, search, read, verify
Aloha,
K
paka is offline   Reply With Quote
Old   October 15, 2010, 08:41
Vesselin Krastev
name1
name2
Aloha,
K
Yes, it's like Paka said. I've verified it on my own and it works: you just have to declare some different forceCoeffs-type functions into the controlDict (the name is not important, what is important is do declare them properly), each one referred to the patch of interest. By doing so, during the run time the code will store the force coefficients in different folders, named as the different functions are.
Regards
V.
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 12:21
Multiple domain/Multiple material problems... possible or not? Amiga500 OpenFOAM 1 April 14, 2010 15:32
Number density tracking rather than particle tracking Rebecca Main CFD Forum 2 April 23, 2009 12:52
High values of Cdrag DAK565656 Main CFD Forum 21 September 5, 2005 17:16
Particle Tracking Pravir Kumar Rai FLUENT 2 January 30, 2003 19:16
