openfoam in windows xp
Old   October 18, 2010, 06:43
Default openfoam in windows xp
ssixr's Avatar
sudhir
ssixr is on a distinguished road
hello friends,
i using windows version of openfoam.i am trying to simulate detonation. as i am new to openfoam and it works well in linux OS, i am facing diffculities in running the files.can you suggest me a tutorial book/link to work in windows based openfoam..
thank you
sudhir
ssixr is offline   Reply With Quote
Old   October 18, 2010, 06:55
Retired Super Moderator
Bruno Santos
Greetings Sudhir,
Here is a link with a list to various sources about OpenFOAM for Windows. That link itself is to a page that talks about cross-compiling OpenFOAM In Linux for Windows.
As for asking questions about OpenFOAM for Windows, you should have asked on this forum: OpenFOAM Windows Installation
Best regards and good luck!
Bruno
Old   October 18, 2010, 07:26
Elvis
elvis will become famous soon enough
Originally Posted by ssixr View Post
hello friends,
thank you
sudhir
Are you afraid of Linux or why do you prefer Windows?
There are several Linux LiveDVD that include OpenFoam, you do not have to install Linux on your Computer to get your fingers on OpenFOAM.
These LiveImages work out of the box and are quite useful for learning OF/ (or handling smaller cases). A real installation is only nescessary for real problems
And some basic linux comands are explained in the tutorials from the OF workshop.
Maybe you make faster progress using a liveDVD LiveUSB-stick
elvis is offline   Reply With Quote
Old   October 20, 2010, 03:34
Default reply for wyldckat
ssixr's Avatar
sudhir
Bruno, thank u very much for your useful links..see you in openfoam windows forum..can you suggest me some linux livedvd OS?
Last edited by ssixr; October 20, 2010 at 03:51. Reason: wrongly mentioned the name
Old   October 20, 2010, 03:46
Default reply for Elvis
ssixr's Avatar
sudhir
hi
thanks for your reply.actually i am familiar with linux(ubuntu) and unix(sun solaris) but the computer wic i am working now has some technical difficulties in installing full version of linux OS.so i moved to windows version.can you mention few linux OS which has preintalled openfoam software? will SUSE be better?
once again thank you.
sudhir
Old   October 20, 2010, 07:35
Bruno Santos
Hi Sudhir,
You have at least two choices for LiveDVDs:
Best regards,
Bruno
Last edited by wyldckat; October 20, 2010 at 07:36. Reason: ooops, typo on Sudhir's name...
Old   October 20, 2010, 10:26
FG_HSRM is on a distinguished road
Hi
Just for the sake of completeness, there is also a Ubuntu based Version:
fritz
FG_HSRM is offline   Reply With Quote
Old   October 26, 2010, 02:12
Default thanks guys
ssixr's Avatar
sudhir
hello guys
thank you bruno and fritz.becoz of ur valuable guidance i downloaded opensuse. i am using virtual box and powerdvd for mounting the image...is it ok guys?
Old   October 26, 2010, 17:20
Bruno Santos
Hi Sudhir,
If it works, then it works!
Although I believe you can define in Virtualbox to read directly from the ISO file, so this way you wouldn't need PowerDVD to open the ISO.
Best regards,
Bruno
Old   October 27, 2010, 07:07
Bruno Santos
Greetings Iwarelogic and welcome to the forum,
You're setting up yourself to be catalogued as a spammer! Why? Because you've only made one post and already have added a link to your signature, which is a big no no
Now for your question:
Originally Posted by Iwarelogic View Post
I recently tried to install open Foam in my windows XP but it is unable to install. Can anyone help me know the valid reason and provide me with appropriate solution
I believe you must have installed the package from the project openfoam-mswin. That project was unofficial and was apparently only a proof-of-concept and looks to be abandoned. But uninstalling it should be as easy as removing the folder where it installed itself. Likewise for the start menu group that I think it also sets up.
Best regards,
Bruno
Old   October 30, 2010, 03:30
Default hi bruno
  #11
ssixr's Avatar
sudhir
hi bruno
i tried to use virtual box but its not working and showing error like"its a 32 bit operating system"[i downloaded 64 bit opensuse as my comp is 64bit]. so i dropped the idea of using vbox..now i am using live cd to work with opensuse.we can directly install openfoam from internet right? what is your opinion about geekocfd?
thank you for your replies
yours
sudhir
Old   October 30, 2010, 07:08
Bruno Santos
Hi Sudhir,
Well, running a x86 virtual machine in a x86_64 is faster than running a x86_64 virtual machine in a x86_64, at least by my experience.
I believe that GeckoCFD should be very good. I've not tried it yet, but Alberto knows his way around OpenSUSE and OpenFOAM, so I can only assume it's a very good package.
But check the latest post on GeckoCFD's thread:
Originally Posted by alberto View Post
However, if you manage to install openSUSE 11.3 without my image, I can link you to the binaries I pre-built.
You can install the normal OpenSUSE 11.3 and request Alberto to provide the links for the pre-built binaries.
Best regards,
Bruno
Old   October 31, 2010, 02:48
ssixr's Avatar
sudhir
Hi Bruno,
wat u said about virtual machine is true the x86_64 version works faster..thanks.successfully i downloaded the geekocfd from opensuse studio gallery.then i burned the iso file in a dvd using "burn iso file " option available in nero 7. but its not booting like a livecd. only my xp OS is booting..simply saying my bootable live cd is not working...have u come across anything like this? any suggestions?
thank you
truly
sudhir
Old   October 31, 2010, 08:38
Bruno Santos
Hi Sudhir,
Well that's odd. Did you first test the ISO in a virtual machine? Because if it boots well in a virtual machine, then I can only think a few possibilities:
  • BIOS isn't configured to boot first from CD/DVD - you can try an official LiveCD version of OpenSUSE or Ubuntu or some other bootable CD/DVD you might have.
  • There was an error while recording to the DVD - this happened to me a few days ago, where half a byte was damaged... which is enough to damage most binary files
If neither one of these is the case, then I suggest you ask Alberto directly on his thread for GeckoCFD: http://www.cfd-online.com/Forums/ope...tml#post278288
Bruno
Old   November 2, 2010, 06:39
ssixr's Avatar
sudhir
hi Bruno,
you are 100% correct in your guess.the error occured because of dvd writing problem not a problem of iso file.first i checked the iso in vbox and it was running.then burned the dvd in other computer and it is running properly except some graphical errors. its good man..thanks for all your help..hopefully i will finish my detonation
truly
sudhir
Old   November 19, 2010, 04:21
Default Other possibility
  #16
Govanni Aloisi
giovan is on a distinguished road
I installed Ubuntu 10.04 LTS (Long Term Support) inside Windows XP using Wubi on three different computers. Installation of OF 1.7.0 and, later, 1.7.1 was just copy and paste from the OF home site installation instructions. Running speed is as in native Ubuntu system. Never had problems.
cheers
giovan is offline   Reply With Quote
Old   November 19, 2010, 04:40
akidess's Avatar
Anton Kidess
Installing with WUBI pretty much is a native installation, it just saves you the effort of partitioning.
cheers
Old   November 19, 2010, 05:44
Govanni Aloisi
Partioning the disk is a risky business.. And reverting is a Job for experts. Wuby install can be removed by the install/remove app of Win XP. I would recommend this path as the simplest one.
But I know I'm lazy..
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
Windows 64-bit with Native MPI patch for OpenFOAM 1.6.x gocarts OpenFOAM Announcements from Other Sources 4 October 4, 2010 08:56
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
Cross-compiling OpenFOAM 1.6 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 7 January 19, 2010 15:39
OpenFOAM NetgenNeutralToFoam Windows J-man OpenFOAM 2 August 7, 2009 02:25
