LES model (oneEqEddy), air entrainment predictions
Old   November 4, 2010, 15:02
Default LES model (oneEqEddy), air entrainment predictions
N. A.
N. A. is on a distinguished road
Hello Foamers,
So I am trying to model a coal+O2 jet along with an H2O annular jet in a cylidnerical geometry using coalChemistryFoam. I find that if I use LES model, the mean velocity field is over predicted in the domain, i.e. the jet does not seem to sexpand and entrain the surrounding air. in LES I see that there is a high velocity at the outlet boundary. ? --Dont understand why this happends..Is this a boudnary condition issue
On the other hand the RANS model predicts that the velocity decays because of air entrainment and mixing.
the inlet boundary condition for velocity is fixed value and turbulent inlet. the outlet velocity boundary condition is inletOutlet. for pressure I am using total pressure value for both inlet and outlets.
Attached are the plots comapring velocit field predicted using RANS and LES. LES does not rpedict decay of jet velocity as usually the trend with jets, but RANS is able to do that.
Any inputs as to why LES is nto able to match the trends and what can be done, will be very helpful.
Thanks,
Nir
N. A. is offline   Reply With Quote
Old   November 7, 2010, 13:17
Eugene de Villiers
eugene is on a distinguished road
You need to use a mapped inlet for U and k to obtain the correct inlet turbulence and thus spreading rate. See tutorials/incompressible/pisoFoam/les/pitzDailyMapped
eugene is offline   Reply With Quote
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 07:18
adapt offset cylinder model for les turbulence shackman287 OpenFOAM 0 August 19, 2010 21:10
LES model of PHOENICS David Phoenics 4 July 11, 2007 19:44
How to apply negtive pressure to outlet bioman66 CFX 5 June 3, 2006 01:40
Algebraic Dynamic LES model noName CFX 0 March 24, 2005 17:35
