October 24, 2010, 21:33 |
volScalarField, initialization
Nadeem
Hello Everybody,
I am struggling to initialize volScalarField with internalField and also with path values. I found out following structure. volScalarFial A { IOobject("A",runTime.timeName(),mesh,IOobject::NO_ READ,IOobject::NO_WRITE), mesh, dimensionedScalar("A",A.dim, xyz) } I am not getting what is this xyz, I think its internal field. and to initialize this field by its patch values i did following forAll(A.boundaryField(),patchi) { A.boundaryField()[patchi] = 300; } in this way, 300 gets assigned to the whole boundary patches. when I write it in openfoam, then I get xyz in internal field and 300 at the patches, its right, BUT, when this field is used in a solver that is built in code, and this field is first of all initialized as above mentioned method then it does not give same results as I read in this Field inside the code. I think there is a problem with internal field. Can anyone give me some suggestions? What i want, is to initialize the fields in my code and want to use these fields inside the solver that is also built in my code, in order to save read and write time consumption. Thanks in advance. BEst Regards, |
October 26, 2010, 23:00 |
Santiago Marquez Damian
Rep Power: 23 |
Hello ubaid!!
Can you post a more extense portion of your code? Maybe some includes are overwriting your hard-coded initialization. Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D. Research Scientist Research Center for Computational Methods (CIMEC) - CONICET/UNL Tel: 54-342-4511594 Int. 7032 Colectora Ruta Nac. 168 / Paraje El Pozo (3000) Santa Fe - Argentina. http://www.cimec.org.ar |
field, volscalarfield |
How to create initiate a volScalarField p without reading from disk NO_READ does not seem to work | dbxmcf | OpenFOAM Running, Solving & CFD | 14 | March 25, 2022 06:08 |
if-loop, volScalarField comparison | volker | OpenFOAM | 7 | March 6, 2020 20:03 |
Problems with creating a volScalarField | georlade | OpenFOAM Programming & Development | 4 | December 4, 2016 12:31 |
FMG initialization query | Mohsin | FLUENT | 6 | November 2, 2016 02:02 |
compressor initialization | paglia | FLUENT | 0 | February 1, 2006 15:14 |
