Velocity blows up suddenly after 30,000+ iterations
Hello all,
I am running a 2d turbDyMFoam transient external flow simulation using komegasst and ggi for rotating parts. Qualitatively the simulation is good, all of the flow regimes I have seen in other research papers are forming, and a steady state appears to be almost reached up until the 34,000th time step where the Uy suddenly blows up (output: no. iterations 1000, large final residual), then time step continuity error blows up, etc. Is it unusual for this to happen at such a high iteration count? Can wrong BCs cause this? I have for the k and omega zerogradient on all surfaces except fixedvalue at the freestream inlet and inletoutlet at the freestream outlet. For U, fixedvalue at freestream inlet, inletoutlet at freestream outlet (inletvalue uniform (0 0 0)), movingwallvelocity on physical surfaces, 'slip' on the top and bottom freestream patches. For p, zerogradiwent everywhere except slip on the top and bottom freestream patches and fixedvalue at freestream outlet. |
Hi robert,
may I see the log file of the last 5 iterations before the simulation crashed? It is always a good idea to post not only the description of your problem but also errors/schemes setup and everything else can be useful to understand what is going wrong. Cheers mad |
1 Attachment(s)
I stopped it before it could crash when I saw astronomical numbers for velocity magnitude and cumulative time step continuity error.
I have attached my fvSchemes file. The last time steps before the first abnormal number appeared (where the simulation first messes up that I could find is highlighted in red): Code:
Courant Number mean: 0.00800153 max: 0.249977 velocity magnitude: 19.2813 |
Are you running on multiple processors?
Also, how the vector field looks like at the last saved time step? Actually, I never run any simulation using your solver, but maybe the cause of your problem is similar to something I have already seen... mad |
Yes, I am using metis decomposition for 4 processors on a single desktop.
As for the vector field on the iteration where it first display bad numbers, the whole field is just one color at some high velocity (on the order of the speed of light). The pressure field is all just one color with the scale set at infinity to negative infinity, with infinity and negative infinity both being the same color. At the iteration just before, (I have controldict to save every 25 iterations) the flow field seems normal. I think the iteration that I posted above is the first messed up one, because the velocity magnitude still seems normal before the uy residual blows up. |
Could you run the very last iterations using GAMG on p and smoothSolver on U and turbulence? Start form the last saved time step and go on. Alternatively, run the very last iterations on a single processor. If the solver run successfully the time step you had problems, than we may have found the solution...
Telling this because it remembers me a problem I had some times ago with incompatibility between DILUPBiCG in parallel and turbulence quantities... crossed fingers... :) mad |
Could you give me some pointers on setting up GAMG? I see that there are many parameters to define, and I have not used it before. How do I choose the velue for nSweeps for smoothSolver? (I have looked through the openfoam 1.7 manual) (I use 1.5dev though for ggi)
Thanks for the suggestions, will try out the single processor run and let you know if it works or not. |
p mad |
How dependent is convergence on nsweeps and ncoarsestlevel?
My mesh (ggi, turbomachinery external flow) has about 70000 cells, is ncoarsestlevel=10 appropriate? |
It seems that I have the same problem as you said:
"incompatibility between DILUPBiCG in parallel and turbulence quantities". Switching from DILUPBiCG to GAMG helped. It is stilling running right now, but it at least has not yet crashed so far (further than it went using PBiCG). I am running pisoFoam with RANS. Periodic and wall boundary conditions on my domain. |
Let me know if you will perform any study on the influence of different parameters on GAMG. Enjoy mad |
Could anybody give some insight on that point?
incompatibility between DILUPBiCG in parallel and turbulence quantities. Why is the incompatibility? I am not really satisfied with that solution without explanation. Best, Heng Quote:
Thanks, maddalena! Your diagnosis seems to have been correct.
Since piso is segregated solver (right?) and U was always the first to suddenly mess up, I only changed U to smoothSolver, and everything else in the case was the same. The simulation ran to completion (at least twice as far as previous cases). I will change every other variable besides p to smoothSolver and see if there is any difference. I am hesitant to use GAMG because I dont know how to at least give educated guesses to the parameters. I imagine the standard parameter values are not applied to external turbomachine flow. But thanks again! I dont think I would ever have caught such an error. |
Well, to say the truth, I simply reported an explanation found over here: http://www.cfd-online.com/Forums/ope...tml#post246561. :o
But happy to be useful!!! :D mad |
Do you have some new ideas about this problem? Running with smooth-solver, OK; running with PBiCG in serials, OK; running with PBiCG in parallel, crash. I have the same problem with h equation in reactingFoam. Changing to smooth solver fixes this, but I am curious about the reason. Could you please share some ideas? Quote:
