Setting mass flow rate boundary condition |
October 26, 2010, 13:41 |
Philippose Rajan
Rep Power: 25 |
Hello there,
A Good Evening to you :-)! To specify a flow rate instead of a velocity, you can use the boundary condition: flowRateInletVelocity For an example of how to use it, check the following file in the tutorials folder of OpenFOAM: /compressible/rhoPimpleFoam/angledDuct/0/U Hope this helps. Have a nice day ahead! Philippose |
October 26, 2010, 14:53 |
Dear Philippose,
Thank you very much for your answer. two questions: i think it is suitable for inlet patches, isn't it? i need sth for outlet patch. if i use it for inlet, in tutorial file P type is set to zeroGradient. can we suppose it in flow which comes from a duct as zeroGradient when (as you know) it has pressure drop across the duct? Best regards, Maysam Last edited by maysmech; October 26, 2010 at 15:32. |
October 26, 2010, 18:10 |
Philippose Rajan
Rep Power: 25 |
Hi again,
* If I remember right, you can use the flowRateInletVelocity patch as an output simply by changing the sign of the flow rate value, to indicate that it is flowing out of the domain. * Normally, you cannot specify a fixed velocity (flow rate) and a pressure on the same boundary..... this is why, you need to provide a zeroGradient boundary condition for the pressure when you supply the flow rate as an input parameter. .... I am not sure what you imply by a pressure drop across the input boundary in a duct. * Paraview has a filter which lets you integrate a variable over a surface (I think the filter is called Surface Flow).... this should give you the flow rate, however, I remember that I had an issue trying to interpret the output of this filter..... try it out anyway.... it basically calculates the dot product of a flow field and the normal vectors of the surface. Philippose |
November 4, 2010, 01:20 |
Philippose Rajan
Rep Power: 25 |
The question then is, what exactly did you want to do? a. Specify a uniform flow rate at the input b. Specify a uniform velocity at the input c. Specify a non-uniform velocity profile at the input (spatially non-uniform across the input patch) d. Specify a non-uniform flow rate at the input (spatially non-uniform across the input patch) In case it was (d), how would you specify the flow rate? would it be the flow rate through each patch element face? In which case it would be something like specifying a non-uniform velocity profile where v_face = Q_face / A_face For specifying a parabolic Inlet velocity, you have the boundary condition: "parabolicVelocity" In addition, you could try to create a customised non-uniform velocity / flow inlet using the "groovyBC" library. Have a nice day ahead! Philippose |
November 4, 2010, 01:58 |
Thanks Philippose,
I want it for an outlet patch that is not uniform velocity. for example a T-junction geometry with two different outputs and i want control rate as 20% and 80% in outlets by setting mass flow rate. Best, |
December 16, 2011, 03:53 |
Bernhard
Rep Power: 21 |
Hi Maysam,
Did you ever get this to work? I am also interested in such a boundary condition with a mass flow rate that is dictated, but also keeps in some way the zero gradient condition there. |
August 21, 2013, 03:23 |
H.Martens
I am, too!
August 21, 2013, 03:39 |
#11 |
Niels Nielsen
Rep Power: 27 |
Hi
you can use something lige this (OF22) for inlet use zeroGradient for outlet use this Code:
outlet { type flowRateInletVelocity; volumetricFlowRate constant -0.1; // m3/s, negative sign means out of the domain value uniform (0 0 0); }
Linnemann PS. I do not do personal support, so please post in the forums. |
February 6, 2014, 02:37 |
#12 | |
Mehdi GHOZALI
Rep Power: 12 |
Thank you |
May 28, 2015, 09:49 |
#13 |
James F.
Rep Power: 9 |
I have a quite similar problem and I cannot find the answer.
I am using buoyantPimpleFoam currently. I have inlet : U is fixedValue / P is zeroGradient / T is fixedValue suction_outlet : U is zeroGradient / P is fixedValue (0.995e5) / T is zeroGradient secondary_outlet (actually, suction_outlet sucks air from this patch in addition to air from the inlet) : U is zeroGradient / P is fixedValue (1e5) / T is inletOutlet (calculated with internalField - to prevent air coming inside the domain from this patch being at 0K). I'd like to change my suction BC to have a given volumicFlowRate rather than fixed pression which is causing instability. I tryed something like : Code:
U suction { type flowRateInletVelocity; volumetricFlowRate constant -130; // m3/s, negative sign means out of the domain value uniform (0 0 0); } P suction {type zeroGradient} Do you have any advice? Thanks!! PS : What does the line " value uniform (0 0 0);" in flowRateInletVelocity stands for? EDIT - PB SOLVED: I had a unit problem. Last edited by NoradFirst2; June 9, 2015 at 07:52. Reason: Problem solved |
June 15, 2016, 02:59 |
#14 | |
Fatemeh
Rep Power: 10 |
Hi! I have a similar problem. Would you please tell me, when defining flowRateInletVelocity, do we have to enter discharge massFlowRate or discharge/area? I have determined it like this: type flowRateInletVelocity; massFlowRate constant 0.2512; but it has another part, value, what doest it want? also, would you please tell me, if I define a slip wall for atmosphere, I should define value uniform (0 0 0) for it? why? Not that I have an open channel which I want to specify slip wall instead of atmosphere in the surface. Thanks |
December 6, 2018, 05:42 |
Cyclic mass flow rate
#15 |
Calum Roberts
Rep Power: 7 |
Hi there,
I am trying to set up a cyclic case where a specific mass of water passed through the system each second. Because my patch type is cyclicAMI i cannot use the flowRateInletVelocity type. Does anyone have any ideas on how to do this? Any help would be appreciated! Calum |
July 22, 2021, 11:30 |
#16 | |
Masoumeh
Rep Power: 6 |
inlet velocity boundary condition | murali | CFX | 5 | August 3, 2012 08:56 |
How to change from mass flow to volume flow rate | stanley | FLUENT | 1 | February 2, 2007 06:44 |
Target mass flow rate | Saturn | FLUENT | 0 | December 10, 2004 04:18 |
Mass flow boundary condition | Síle | FLUENT | 0 | June 12, 2003 07:30 |
Constant mass flow rate / choking outlet bounardy condition | Min Zhu | Main CFD Forum | 1 | September 29, 1998 15:33 |
