October 31, 2010, 12:50 |
some basic problems, little help needed
Jakub
Rep Power: 15 |
Can you do please provide me the correct order of commands for tutorial cases of ,,motorbike" and ,,nacaAirfoil".
I know that in order to run ,,cavity case" I should change direction in ternminal to cavity folder, then run ,,blockMesh" command, then ,,icoFoam" and finally ,,paraFoam" to post-process... but when ot comes to ,,motorbike" case i don't know which commands to use. Ok, so when I change direction to motorbike folder, then I type ,,blockMesh" in order to generate... hmm... some mesh, but in the folder I can see that there's also a file describinb a mesh of motorbike in snappyHexDic, so I think, that I should run now ,,snappyHexMesh" and that the code of the program would figure something out of it, but I get an info that there's a fatal error, ////////////////// *---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.7.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 1.7.1-fffd2c682d50 Exec : snappyHexMesh Date : Oct 31 2010 Time : 18:41:38 Host : ubuntu PID : 2155 Case : /home/btgyachtdesign/OpenFOAM/btgyachtdesign-1.7.1/run/tutorials/incompressible/simpleFoam/motorBike nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 --> FOAM FATAL IO ERROR: cannot open file file: /home/btgyachtdesign/OpenFOAM/btgyachtdesign-1.7.1/run/tutorials/incompressible/simpleFoam/motorBike/system/fvSolution at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 61. FOAM exiting ///////////////////// where's my mistake? How to solve this problem? What am I doing wrong? What is more, the motorcase is most interesting for me to understand, since I want to use openFoam to design opitmised sails and bulbs/keels. I want to make a virtual wind/hydro tunnel to investigate diffirent cases. I know that a lot of work to do is ahead, but I still want to figure out how to work with openFoam. I would be honoured if you could spend this few seconds and share the commands being used in those cases. That would be very helpful. Kind Regards, Kuba |
October 31, 2010, 13:34 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Kuba and welcome to the forum!
It's quite simple: in the tutorial folders, always look for the scripts Allrun and Allclean. They are either in the tutorial case folder, or in the parent folder. Only when there isn't one, you then can simply run blockMesh and the solver whose name is given to the parent folder. To run either one of the scripts (when they exist) run like so for running the case: Code:
./Allrun Code:
./Allclean
Best regards and good luck! Bruno
October 31, 2010, 14:25 |
Jakub
Rep Power: 15 |
Bruno,
Thank you very much for fast and helpful answer . Now I'll have to play a little bit with openFOAM. I ran the ,,foamRunTutorials" command with the motorbike case, but launching Paraview and applying the case to post-process I can see only the ,,Bounding box" of the wind tunnel and when I turn on the glyphs, their direction seems to be unaffected by the mesh of the motorbike, ie each glyph has a direction exactly along x coordinate. It seems like the code missed to load the bike. Apart from that tiny inconvenience, everything seems to work very well. The question is where now the problem is? Kind Regards, Kuba |
October 31, 2010, 15:25 |
Bruno Santos
Rep Power: 128 |
Hi Kuba,
I've got a feeling you skipped the cavity tutorial explanation in the user guide... anyway, here is the post-processing section for the cavity tutorial: http://www.openfoam.com/docs/user/ca...#x5-130002.1.4 To sum up:
Best regards, Bruno
October 31, 2010, 15:34 |
Jakub
Rep Power: 15 |
Could you please provide more details on where is this combo box located...
October 31, 2010, 15:48 |
Bruno Santos
Rep Power: 128 |
Hi Kuba,
Oooops, I forgot it said "Outline", not "boundary box". Well, attached is a picture showing the controls I talked about. Best regards, Bruno
October 31, 2010, 16:02 |
Jakub
Rep Power: 15 |
Ok, so I figured it out with the outlines, but the problem is that in Mesh Regions dialog I don't have any mesh names under ,,upper wall" box, so no parts for motorbike... It seems like ./Allrun command missed to attach the motorBike snappyHexMesh meshes generated from .stl for me... What do you think?
October 31, 2010, 16:11 |
Bruno Santos
Rep Power: 128 |
Hi again Kuba,
I forgot to tell you I was using the internal foam reader, not OpenFOAM's original reader. So what you see on the lower left corner of my attached picture will be different from yours. I'm going to assume you are using the Debian packages version of OpenFOAM. If so, you can run the following command for changing to the internal reader: Code:
sudo sed -i -e 's=\.OpenFOAM=\.foam=' $WM_PROJECT_DIR/bin/paraFoam If you want to change back to the original reader, run: Code:
sudo sed -i -e 's=\.foam=\.OpenFOAM=' $WM_PROJECT_DIR/bin/paraFoam Bruno
October 31, 2010, 16:28 |
#9 |
Jakub
Rep Power: 15 |
Hi Bruno,
I did use the code you given me. In the screenshot ( http://img180.imageshack.us/img180/7...utekranuuc.png ) you may notice, that there are certain meshes of motorbike missing in window ,,Mesh Regions" to be shown/imported. The ,,items" I have are only: internalMesh, frontAndBack, inlet, outlet, lowerWall, upperWall. So running of the code you provided, didn't solve the problem. What is your suggestion now? Regards, Kuba |
October 31, 2010, 18:11 |
#10 |
Bruno Santos
Rep Power: 128 |
Hi Kuba,
Mmm, there should be some logs in the folder after you ran foamRunTutorials. If not, try running: Code:
./Allrun And probably something did go wrong with snappyHexMesh, since you do have the mesh generated by blockMesh, but not the motorbike mesh. Best regards, Bruno
November 1, 2010, 04:18 |
#11 |
Jakub
Rep Power: 15 |
There's indeed some problem with snappyHexMesh.
The log file doesn't look very optimistic, too much fatal erors for me LOG FILE: // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Read mesh in = 0.05 s Overall mesh bounding box : (-5 -4 0) (15 4 8) Relative tolerance : 1e-06 Absolute matching distance : 2.29783e-05 Reading refinement surfaces. Read refinement surfaces in = 4.31 s Reading refinement shells. Refinement level 4 for all cells inside refinementBox Read refinement shells in = 0 s Setting refinement level of surface to be consistent with shells. Checked shell refinement in = 7.92 s Determining initial surface intersections ----------------------------------------- --> FOAM FATAL ERROR: Number of cells in mesh:1280 does not equal size of cellLevel:318755 This might be because of a restart with inconsistent cellLevel. From function hexRef8::getLevel0EdgeLength() const in file polyTopoChange/polyTopoChange/hexRef8.C at line 357. FOAM aborting #0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::error::abort() in "/opt/openfoam171/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Foam::hexRef8::getLevel0EdgeLength() const in "/opt/openfoam171/lib/linuxGccDPOpt/libdynamicMesh.so" #3 Foam::hexRef8::hexRef8(Foam:olyMesh const&, Foam::List<int> const&, Foam::List<int> const&, Foam::refinementHistory const&) in "/opt/openfoam171/lib/linuxGccDPOpt/libdynamicMesh.so" #4 Foam::meshRefinement::meshRefinement(Foam::fvMesh& , double, bool, Foam::refinementSurfaces const&, Foam::shellSurfaces const&) in "/opt/openfoam171/lib/linuxGccDPOpt/libautoMesh.so" #5 in "/opt/openfoam171/applications/bin/linuxGccDPOpt/snappyHexMesh" #6 __libc_start_main in "/lib/libc.so.6" #7 in "/opt/openfoam171/applications/bin/linuxGccDPOpt/snappyHexMesh" Aborted How to cope with this? |
November 1, 2010, 05:49 |
#12 |
Bruno Santos
Rep Power: 128 |
Hi Kuba,
That has happened to me as well in the past and it was due to switching execution steps. Run: Code:
./Allclean ./Allrun If not, try copying the case from the original version again, since something else might have been damaged in the previous executions. Best regards, Bruno
November 1, 2010, 13:27 |
#13 |
Jakub
Rep Power: 15 |
Let the attachment explain everything ( http://img512.imageshack.us/img512/9...eldfinally.png ) . Finally I succesfully ran the case, thank to your help . I have a few more question, though... generally speaking I plan to use this case with substituted .stl file to analyze flow over sails and keels. Do you reccomend this case for this application? What modifications shall I take under consideration? Best Regards, Jakub |
November 1, 2010, 14:22 |
#14 |
Bruno Santos
Rep Power: 128 |
Hi Jakub,
I'm glad you've finally got it working! But sadly, this is as far as I can help My CFD experience is seriously limited. If you don't understand why, read this: Read this before emailing/PM me In my signature link, at the end of that blog post, you can find a few links that might be helpful for someone like you who is starting to use OpenFOAM. Best regards and good luck! Bruno
November 1, 2010, 16:50 |
#15 |
Jakub
Rep Power: 15 |
Could you please send me the original file with motorBike case, because I have unluckily modified it and now I don't know how to fix it ;/ I made a copy of it at the beggining, but after rebooting my computer, I realised that i wasn;t working on the copy of the folder at all, but on the original cases me, stupid...
Needed Benchmark Problems for FSI | Mechstud | Main CFD Forum | 4 | July 26, 2011 12:13 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
Two-phase air water flow problems by activating Wall Lubrication Force | challenger85 | CFX | 5 | November 5, 2009 05:44 |
Problems installin OpenFoam-1.5-dev in Ubuntu 8 | tmata2002 | OpenFOAM Installation | 2 | September 23, 2009 10:50 |
boussinesq model problems help needed | nabeel mohsin | Main CFD Forum | 1 | July 29, 2004 19:10 |
