October 22, 2010, 11:53 |
Forces calculation
Rep Power: 16 |
Hello OpenFOAM users&fans,
I am new to OpenFOAM and I am simulating a 2D flow over a cylinder with pisoFoam. When I am trying to find the forces, the forces.dat file only shows brackets full of zeros. The forces code seen below creates a forces/0 folder where forces.dat is located. I am referring to the right patch in the code. Do you have some suggestions or ideas of what could be wrong? This is my forces code in my controlDict.h functions ( forces { type forces; functionObjectLibs ( "libforces.so" ); outputControl timeStep; outputInterval 1; patches (wall); pName p; UName U; log true; rhoName rhoInf; rhoInf 1025; CofR ( 0 0 0 ); } ); |
October 29, 2010, 10:23 |
Nick Gardiner
Rep Power: 17 |
Hi
Is your cylinder named wall? If not change the patches (wall); line in forces{... } to patches (whatever you've called it); Hope that helps Nick |
October 29, 2010, 10:30 |
Vesselin Krastev
Rep Power: 20 |
If the patch name is correct, try also to remove the lines beginning with pName and Uname: judging by other treads in the forum, these lines can give some troubles in the 1.7.x versions of OpenFOAM.
Regards V. |
October 29, 2010, 10:50 |
Juanito
Rep Power: 15 |
Any one knows if there are problems with force function in 3D multifaces patch?
Thankyou. |
October 29, 2010, 11:38 |
Rep Power: 16 |
It was just a stupid mistake, for some reason I had changed my patch name to something else than "wall". It is fixed now, thank you.
Forces viscous calculation in VWT with OpenFOAM 15x | terrybarnaby | OpenFOAM Running, Solving & CFD | 0 | November 28, 2008 08:39 |
Calculation of pressure forces in Fluent | Maharba | FLUENT | 2 | June 29, 2007 01:14 |
forces calculation | Chien | CFX | 9 | June 23, 2005 11:45 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
Calculation of forces | Michal Marcinkowski | Main CFD Forum | 2 | January 18, 2001 04:37 |
