Change mesh location on drive..
Old   November 4, 2010, 05:51
Default Change mesh location on drive..
Mark Herskind
MarkHerskind is on a distinguished road
Hi..
I have a mesh, which is want to do 12 simulations on (changing inflow direction).. The mesh I have right now is app 7.5m cells, which is about 1.5GB of data..
If I want to run these simultanious, I will need to generate 12 cases, each with a copy of the mesh.. It'll take up a lot of space copying the grid to each sector (14.5GB of duplicate data), but worse, it takes time..
I was wondering if there's a way of changing the reference to the mesh location, so that the simulations can share the same mesh..
Cheers
Mark Herskind
MarkHerskind is offline   Reply With Quote
Old   November 4, 2010, 18:04
Retired Super Moderator
Bruno Santos
Greetings Mark,
It depends on where the mesh is kept at. For example, when we run "blockMesh", the mesh is kept in the folder "constant/polyMesh". The same happens when we run "snappyHexMesh -overwrite", which will overwrite the latest mesh (which is usually the initial mesh by blockMesh).
So, if you can keep the mesh in the folder "constant/polyMesh" then you can use symbolic links for sharing the mesh between cases. For example, if we have 3 case folders: "case1 case2 case3".
Generate the mesh in case1. Then step back into the previous folder and run:
rm -rf case2/constant/polyMesh
rm -rf case3/constant/polyMesh
ls -s ../../case1/constant/polyMesh case2/constant/polyMesh
ls -s ../../case1/constant/polyMesh case3/constant/polyMesh
Now, I haven't tested this yet, but at least in theory it should work. If you run the following commands:
cd case3/constant
ls -l polyMesh/
It should show the contents of the case1's polyMesh folder.
But the best method would be to use absolute folders, as long as you run always on the same path:
ls -s $PWD/case1/constant/polyMesh case2/constant/polyMesh
ls -s $PWD/case1/constant/polyMesh case3/constant/polyMesh
The variable $PWD holds the path of the current folder. If you don't believe me run:
echo $PWD
Best regards and good luck!
Bruno
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
Open\/Foam change of mesh diffusivity in meshMotion. DLC Main CFD Forum 0 November 26, 2009 10:55
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
