Can't find ggi tools in the version 1.7.0
Old   November 2, 2010, 10:43
Default Can't find ggi tools in the version 1.7.0
kalyan
hardykalyan is on a distinguished road
Need to use the ggi for dynamic mesh generation and for the rotating surfaces. Couldn't find the tools in 1.7.0 version i have installed.
Requesting suggestions to solve the problem.
hardykalyan is offline   Reply With Quote
Old   November 2, 2010, 12:12
Simon Lapointe
Simon Lapointe is on a distinguished road
GGI is available in OpenFOAM-1.5-dev. See http://www.extend-project.de/ for more info about OpenFOAM extend and http://openfoam-extend.svn.sourcefor...enfoam-extend/ to get the source code.
Simon Lapointe is offline   Reply With Quote
Old   November 2, 2010, 13:51
Default Is there a better tool than Ggi ?
kalyan
Thank you Simon.
As 1.5 dev is an old edition, is there any other better tool integrated into the updated version which can help me in producing the better results?
The model I wanna simulate is a cylinder that includes a rotor with 7 blades placed in a fluid.
Suggestions please..
Old   November 2, 2010, 14:55
Nima Samkhaniani
nimasam is on a distinguished road
as i know :
openFoam 1.5.dev is not an standard version of openFoam and its not supported by CFD online, its a fantastic cooperation between openFoam developers
nimasam is offline   Reply With Quote
Old   November 3, 2010, 02:21
bb_
bb_ is on a distinguished road
you may want to check this thread: http://www.cfd-online.com/Forums/ope...x-1-5-dev.html for more details on the differences between the dev and official branches of OF. to my knowledge, the 1.5-dev version are not in anyway outdated as they are not really comparable to the "official" 1.5 version released by opencfd.
bb_ is offline   Reply With Quote
Old   November 3, 2010, 05:41
Default Help to install the 1.5 dev version !
kalyan
I already have the 1.7.0 version installed on my system and i would like to install the 1.5 dev version to obtain the additional tools necessary for my simulation.
Please help me in the installation process and also let me know if i need to remove the previous installation (version 1.7.0) and how.
Old   November 4, 2010, 02:31
Elvis
elvis will become famous soon enough
just a question are you using a Debian/Ubuntu based Linux?
If so, you might take advantage of Oliver Borm work https://launchpad.net/~cae-team/+archive/ppa
Otherwise you have to compile.
But you can use more than one Version of OpenFoam, you just have to work with an alias to point to the version you want to use
http://openfoamwiki.net/index.php/In...ntal_Variables
add the following line to your ~/.bashrc
alias startOF15="source /usr/lib/OpenFOAM-1.5/etc/bashrc"
alias startOF17 ...
extract from live DVD .bashrc
## OpenFOAM specific settings:
# because of bug: http://bugs.debian.org/576837
export PYTHONPATH=/usr/lib/paraview:${PYTHONPATH}
export CSF_GraphicShr=/usr/lib/libTKOpenGl-6.3.0.so
alias startOF15dev='source /usr/lib/OpenFOAM-1.5-dev/etc/bashrc'
startOF15dev
# source the OpenFOAM aliases (src, tut, sol, ...)
source $WM_PROJECT_DIR/etc/aliases.sh
# create $FOAM_RUN directory
mkdir -p $FOAM_RUN
elvis
elvis is offline   Reply With Quote
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
Where to find the difference between fluent 6.3 and version 6.2? legendyxg FLUENT 1 May 7, 2009 03:12
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
[Technical] How to use the socalled bcellShapeb tools Luckyluke (Luckyluke) OpenFOAM Meshing & Mesh Conversion 1 January 6, 2005 01:10
where to find old version Fluent tutorial guid Roger FLUENT 0 March 11, 2002 17:04
