Meshing
Old   November 8, 2010, 02:19
Default Meshing
Rickard
Rickard.Solsjo is on a distinguished road
Hey dudes!
Putting my complex geometry into a simpler case; I want to have two boxes on top of each other and have some kind of interface between these, so that the wall disappears. Then I can refine the first box more than the second box and mesh without using to much PCU.
Should not be to hard right?
Thx
Rickard
Rickard.Solsjo is offline   Reply With Quote
Old   November 8, 2010, 04:15
akidess's Avatar
Anton Kidess
I'm not 100% sure if I understood you right: The interface you are mentioning is purely virtual? You can just make a block mesh with two hexa blocks that share a common face, and then you can have different meshes on each block.
Old   November 10, 2010, 03:05
Rickard
Yeah of course
But if I want to put one of the sides as inlet and the other one as outlet, kind of like a channel or whatever, what should I do with the shared interface?
I tried some different setups but it doesnt work, any ideas?
Old   November 10, 2010, 04:15
akidess's Avatar
Anton Kidess
I think it would help if you drew a sketch, because I still don't see the problem. You don't even have to define a patch between both blocks, it should be recognized as an internal face.
Old   November 10, 2010, 04:39
akidess's Avatar
Anton Kidess
Ok, so your mistake is that the two blocks you defined do not have a common face. Even though they are at the same location, as far as I know blockMesh does not do any checks if it can merge two faces.
Here's an example of a cavity with refinement towards the interface. It should be straight forward to apply this to your case. Now I've only use blocks that are refined in a single, independent direction (here: y, where as x and z which lie in the common face are equal). I'm not sure if it's possible to have a different amount of cells on either side of the interface as that would require interpolation. Someone else will have to comment on that.
vertices
	(0 0 -0.01)
	(0 1 -0.01)
	(1 1 -0.01)
	(1 0 -0.01)
	(0 0 0.01)
	(0 1 0.01)
	(1 1 0.01)
	(1 0 0.01)
              (0 1.2 -0.01)
              (1 1.2 -0.01)
              (0 1.2 0.01)
              (1 1.2 0.01)
blocks
    hex (0 3 2 1 4 7 6 5) (60 50 1) simpleGrading (-4 0.25 1)
    hex (1 2 9 8 5 6 11 10) (60 12 1) simpleGrading (-4 2 1)
edges
patches
    patch bottom
	(4 7 3 0)
    patch top
	(10 11 9 8)
    patch left
	(4 5 1 0)
              (5 10 8 1)
    patch right
	(7 6 2 3)
              (6 11 9 2)
    empty default
Old   November 10, 2010, 05:14
Rickard
Hi, thx man.
Tho it isnt working atm, but I get you aim.
Basically what you do is just to neglect the inner interface by leaving it undefined?
Old   November 10, 2010, 05:26
akidess's Avatar
Anton Kidess
I could add the inner face to the 'empty' default patch - the main point is to repeat the vertices that make up the shared face (here 1 2 5 6) in the block definition:
Btw, I noticed I had a negative number in the grading. That's because I used that mesh with an enhanced blockMesh tool (it's somewhere here on the forum) which applies a sort of parabolic grading when it comes across a negative number. It won't work with the standard blockMesh like this.
Old   November 10, 2010, 09:47
Rickard
Wont you get the 2D 1D problem?
Also, I just leave the faces undefined and after running blockMesh i simply change in the boundary file from deafultFaces to walls. Should work..
Old   November 10, 2010, 10:28
akidess's Avatar
Anton Kidess
I'm sorry Rickard, but you lost me again...
[GAMBIT] Desperate student needs help meshing 3D GAMBIT model - please help! lau06165 ANSYS Meshing & Geometry 1 March 22, 2010 01:09
Best Meshing scheme for Cylinder Nutrex Main CFD Forum 4 July 29, 2008 11:03
Meshing locks workbench window. andy2o CFX 0 February 1, 2008 05:01
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 11:09
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 11:08
