March 23, 2010, 04:19 |
StreamFunction Utility in OF1.6
Maruthamuthu Venkatraman
Rep Power: 17 |
Dear Foamers,
I can able to write data by using this utility "StreamFunction". When i upload this data as point Fields in paraFoam, it doesnt display. The following message shows up. /usr/local/OpenFOAM/OpenFOAM-1.6.x/bin/paraFoam: line 109: 4687 Segmentation fault paraview --data="$caseFile" Any hint will be useful. Thanks |
April 12, 2010, 10:41 |
Rep Power: 17 |
Dear Foamers,
Actually internal mesh has to be checked out, only boundaries should be included when we open data in paraview. Then we can see the streamfunction predicted by OpenFoam. May be its useful to somebody. |
April 13, 2010, 13:55 |
#3 | |
Primoz Ternik
Rep Power: 17 |
I have the same problem with OF-1.5; I am able to run streamFunction utility, but I can not load (view) results with ParaView, even if I "check out" the internal mesh! Do you (or anyone else) have any hints on this? Thanks and enjoy, Primoz |
April 13, 2010, 14:27 |
Rep Power: 17 |
You should include StreamFunction data aswell, Its there in point fields. Except internal mesh checkin all the rest . Atleast in OF1.6 it works . Just try it out and reply me if it works.. Regards |
April 13, 2010, 15:21 |
#5 | |
Primoz Ternik
Rep Power: 17 |
unfortunately I can not see the "streamFunction" data in the "Point Field Status" (in ParaView)! Anyway, thanks for your reply! Cheers, Primoz |
September 28, 2011, 09:28 |
hi every one
i m using openfoam 201
i have problem to plot streamFunction i solved problem for laminar nonisothermal cavity flow with buoyantBoussinesqSimpleFoam. when i run streamfunction then it gave me error but when i run another solver like icoFoam,SimpleFoam then streamfunction works but in buoyantBoussinesqSimpleFoam it cant work so what can i do? plz tel me how can i plot streamFunction? tel me how to plot streamFunction using buoyantBoussinesqSimpleFoam. i found error like, Create mesh, no clear-out for time = 0 Time: 0 --> FOAM Warning : From function streamFunction in file streamFunction.C at line 456 Flux field does not exist. Stream function not calculated Time: 100 Reading field phi Zero face: patch: 0 face: 0 #0 Foam::errorrintStack(Foam::Ostream&) in "/opt/openfoam201/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam201/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #2 Uninterpreted: #3 in "/opt/openfoam201/platforms/linuxGccDPOpt/bin/streamFunction" #4 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #5 in "/opt/openfoam201/platforms/linuxGccDPOpt/bin/streamFunction" Floating point exception abcz@abcz-desktop:~/Desktop/sample$ |
Display Modes | |
Sample Utility not working in OpenFoam 1.6 | titio | OpenFOAM Post-Processing | 6 | November 15, 2014 18:04 |
problem with sampling Utility in openFOAM 1.6 | carmir | OpenFOAM Post-Processing | 10 | February 26, 2014 02:00 |
Sample Utility not working in OpenFoam 1.6 | titio | OpenFOAM Post-Processing | 0 | February 5, 2010 12:12 |
UDF for streamfunction | nisha | Fluent UDF and Scheme Programming | 0 | September 15, 2009 06:55 |
streamfunction from u and v on a coarse mesh | ryoga | Main CFD Forum | 0 | February 1, 2002 18:20 |
