-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   multiphase solver for non-Newtonian fluid (http://www.cfd-online.com/Forums/openfoam/82048-multiphase-solver-non-newtonian-fluid.html)
Benjy November 14, 2010 19:09
Hello Members,
The static mixing of non-Newtonian fluid and nanofluid is to be simulated using OpenFOAM.
A two concentric inlets and one outlet Static Mixer with the 100% non-Newtonian fluid flowing in through one of the inlets and a nanofluid consisting of 50% nano-particle in 50% non-Newtonian fluid flowing in through the other inlet.
My question is, is there any single solver that can handle this problem or is there a way of rewriting the multiphase solver program for Newtonian fluids to solve this case of non-Newtonian Fluid?
Secondly, how can i handle this case of double inlet? I have only handled cases with only one inlet and one outlet.
I am a new user of OpenFOAM and have not much experience.
Thanks while waiting your respond.
anijdon February 18, 2011 17:09
question
hello;
excuse me I have a question about nano fluid flow in openfoam. I want to simulate an incompressible laminar nano fluid flow and heat transfer in steady state. I added energy equation to simpleFoam to obtain termal field for simple incompressible fluid, but I don't know should I use another solver instead of simpleFoam or should change same solver for nano fluid?!:confused: and what's the other solver or how can I change simpleFoam for this type of fluids?
