dynOneEqEddy for Compressible Flow
Like Tree2Likes
  • 2 Post By Fransje
Old   November 12, 2010, 08:38
Default dynOneEqEddy for Compressible Flow
n/a
deji is on a distinguished road
Good morning and good day FOAMERS. I am trying to utilize the compressible flow version of the LES dynamic K equation model and I am getting some error messages. I was utilizing the Smagorinsky LES model before and in need to test the dynOneEqEddy LES model. Does anyone have a sample case just so I can look at the necessary coefficients needed or can anyone give me any feedback as to how to utilize this model. Thanks. Here is the error message. Any help??
Selecting LES turbulence model dynOneEqEddy
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/ayodeji/OpenFOAM/OpenFOAM-1.6.x/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/ayodeji/OpenFOAM/OpenFOAM-1.6.x/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted:
#3 Foam::dimensioned<double> Foam:perator/<double>(Foam::dimensioned<double> const&, Foam::dimensioned<double> const&) in "/home/ayodeji/OpenFOAM/ayodeji-1.6.x/applications/bin/linuxGccDPOpt/fireFoam"
#4 Foam::compressible::LESModels::dynOneEqEddy::ck_(F oam::GeometricField<Foam::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh> const&) const in "/home/ayodeji/OpenFOAM/OpenFOAM-1.6.x/lib/linuxGccDPOpt/libcompressibleLESModels.so"
#5 Foam::compressible::LESModels::dynOneEqEddy::updat eSubGridScaleFields(Foam::GeometricField<Foam::Sym mTensor<double>, Foam::fvPatchField, Foam::volMesh> const&) in "/home/ayodeji/OpenFOAM/OpenFOAM-1.6.x/lib/linuxGccDPOpt/libcompressibleLESModels.so"
#6 Foam::compressible::LESModels::dynOneEqEddy::dynOn eEqEddy(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/home/ayodeji/OpenFOAM/OpenFOAM-1.6.x/lib/linuxGccDPOpt/libcompressibleLESModels.so"
#7 Foam::compressible::LESModel::adddictionaryConstru ctorToTable<Foam::compressible::LESModels::dynOneE qEddy>::New(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/home/ayodeji/OpenFOAM/OpenFOAM-1.6.x/lib/linuxGccDPOpt/libcompressibleLESModels.so"
#8 Foam::compressible::LESModel::New(Foam::GeometricF ield<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in "/home/ayodeji/OpenFOAM/OpenFOAM-1.6.x/lib/linuxGccDPOpt/libcompressibleLESModels.so"
#9 main in "/home/ayodeji/OpenFOAM/ayodeji-1.6.x/applications/bin/linuxGccDPOpt/fireFoam"
#10 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
#11 _start at /build/buildd/glibc-2.9/csu/../sysdeps/i386/elf/start.S:122
Floating point exception
deji is offline   Reply With Quote
Old   November 14, 2010, 15:21
Yi Wang
jason_wy is on a distinguished road
What is your initial condition for k and other fields?
jason_wy is offline   Reply With Quote
Old   November 17, 2010, 05:57
Francois
Fransje will become famous soon enough
Dear Deji,
This doesn't necessarily look like a wrong specification of the turbulence model, but here is a definition of a ./constant/LESProperties file which should work:
LESModel        dynOneEqEddy;
turbulence      on;
printCoeffs     on;
delta           cubeRootVol;
dynOneEqEddyCoeffs
    cubeRootVolCoeffs
        deltaCoeff    1;
    filter      simple;
Of course, you can change the delta and the filter to suit your needs.
As it is a "dynamic" LES model, you have no other coefficients to specify since the coefficients used are determined "on the fly" by the turbulent model.
You should be aware of the fact that, to my knowledge, none of the OpenFOAM LES models are truly dynamic in a local sense, not even the locDynOneEqEddy, but are merely domain averages computed "dynamically" at every time step.
Kind regards,
Francois.
hua1015 and DominicTNC like this.
Fransje is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
What is the difference between liquid reactive flow and gas reactive flow? James Main CFD Forum 6 May 15, 2009 12:14
potential flow vs. Euler flow curious ... Main CFD Forum 23 July 21, 2006 07:40
Plug Flow Franck Main CFD Forum 3 September 4, 2003 05:57
