Home > Forums > OpenFOAM
how to check convergence??
Old   November 19, 2010, 11:23
Default how to check convergence??
Sandeep
gandesk is on a distinguished road
Hello all,
I am new to openFoam and started learning it with the available tutorials. I am able to run the case but I am not sure how to check if the residuals are converging. Where do I check them?? and where do I specify the the convergence criteria??
Any help woud be appreciated!!
Thanks a ton!!
Sandeep
gandesk is offline   Reply With Quote
Old   November 19, 2010, 12:10
FG_HSRM is on a distinguished road
Hello Sandeep!
Take a look at system/fvSolution and check the screen output.
Alternatively you can save the screen output in a log file.
Regards
fritz
FG_HSRM is offline   Reply With Quote
Old   November 19, 2010, 12:15
Sandeep
Hi fritz,
I am sorry I did not understand what u meant to check the screen output. fvSolutions file has just solvers and PISO dictionaries in it.
Old   November 19, 2010, 13:58
How are you running your case?
Normaly, you see something like below on your screen and in the log-file, too.
Time = 0.495
Courant Number mean: 0.116925 max: 0.852134
DILUPBiCG: Solving for Ux, Initial residual = 1.99665e-07, Final residual = 1.99665e-07, No Iterations 0
DILUPBiCG: Solving for Uy, Initial residual = 4.36311e-07, Final residual = 4.36311e-07, No Iterations 0
DICPCG: Solving for p, Initial residual = 1.0746e-06, Final residual = 3.53797e-07, No Iterations 1
time step continuity errors : sum local = 5.37651e-09, global = -2.9125e-19, cumulative = 8.07944e-18
DICPCG: Solving for p, Initial residual = 6.81574e-07, Final residual = 6.81574e-07, No Iterations 0
time step continuity errors : sum local = 8.06059e-09, global = 9.28097e-19, cumulative = 9.00754e-18
ExecutionTime = 0.16 s ClockTime = 0 s
Time = 0.5
DILUPBiCG: Solving for Ux, Initial residual = 1.89493e-07, Final residual = 1.89493e-07, No Iterations 0
DILUPBiCG: Solving for Uy, Initial residual = 4.14522e-07, Final residual = 4.14522e-07, No Iterations 0
DICPCG: Solving for p, Initial residual = 1.06665e-06, Final residual = 3.39604e-07, No Iterations 1
time step continuity errors : sum local = 5.25344e-09, global = -9.50761e-19, cumulative = 8.05678e-18
DICPCG: Solving for p, Initial residual = 5.36118e-07, Final residual = 5.36118e-07, No Iterations 0
time step continuity errors : sum local = 6.86432e-09, global = 4.62063e-19, cumulative = 8.51884e-18
Old   November 19, 2010, 19:50
Robin Gilbert
robingilbert is on a distinguished road
Tutorial of how to plot residuals !
try that link. it shows how to plot residuals.
or u can see the screen output while running the simulation. it shows the initial and final residual at each time step. generally as far as i know if the initial residuals are going down, it means solution is converging. Somebody please correct me if i am wrong.
robingilbert is offline   Reply With Quote
Old   November 21, 2010, 10:20
Default yes!
Mohammad.R.Shetab
mrshb4 is on a distinguished road
you are correct!! but I think thats not enough!! you should monitor some characteristics of your case in some points.( you can try sampleDict for this).
To plot residuals you can try pyFoam. It works properly.
mrshb4 is offline   Reply With Quote
Old   November 22, 2010, 03:41
Elvis
elvis is on a distinguished road
take a look at
http://openfoamwiki.net/index.php/Co...mPlotRunner.py
http://openfoamwiki.net/index.php/Contrib_PyFoam
elvis is offline   Reply With Quote
Old   December 21, 2010, 09:07
GregorS's Avatar
Gregor Seljak
GregorS is on a distinguished road
Hello!
You can also use the foamLog script.
http://www.openfoam.com/docs/user/mo...hp#dx35-201001
GregorS is offline   Reply With Quote
Thread Tools
Trackbacks are On
convergence check implemented in OF-1.6.x vaina74 OpenFOAM Running, Solving & CFD 5 June 3, 2010 08:35
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 08:21
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
