November 22, 2010, 11:15 |
How to impose a flux at the inlet ?
Cyprien
Rep Power: 18 |
Hi !
I want to set up an equation from the knowledge of a flux. My equation has the following form: Code:
ddt(S)+div(phib)=0 As inlet boundary condition, I want to impose a constant flux phib0. Moreover with such inlet, I have been told that S do not need any BC. Is there a simple manner to do that ? Best regards, Cyp |
December 2, 2010, 05:28 |
Cyprien
Rep Power: 18 |
Hi everybody!
I am still on this problem : i do not succeed to impose a flux at the inlet without set up a BC fixedValue for my field S... May be I should try a specific BC ?? which one ? I hope you can unblock me.... Regards, Cyp |
January 26, 2011, 03:27 |
Gert Jan Auwerda
Hi I have the exact same question. I have a CFD problem where I have a fixed mass flux at the inlet and a fixed pressure at the outlet.
As the pressure at inlet will depend on flow properties, the inlet pressure is not known in advance. As the density depends on this pressure, I do no know the inlet velocity. So is there a velocity BC, which lets me input a fixed (total) flux, from which inlet velocity BC is derived? I can make a decent guess of course, but I want to be exact. And running the code a few times, adjusting manually my inflow BC seems a really stupid way. I cannot believe this BC does not exist, it is so common in CFD problems! Please help! |
January 27, 2011, 02:22 |
do you mean? boundaryField { Inlet { type flowRateInletVelocity; flowRate 2.8; // [kg/s] value uniform (0 0 0); // only place holder } Regards, Ralph |
January 27, 2011, 03:05 |
Gert Jan Auwerda
Ah yes, that is the one I was looking for. Thank you very much!
[TGrid] Inlet passage in turbogrid. | soldimix15 | ANSYS Meshing & Geometry | 0 | September 5, 2010 11:34 |
Pulsating flow with non-reflective inlet boundary | cc1000 | CFX | 6 | April 27, 2009 08:10 |
Problems with Inlet species | San24 | Siemens | 1 | May 7, 2008 06:29 |
transitional inlet boundary condition | kamp | CFX | 1 | June 21, 2006 11:08 |
Error in flux at Fluent´s mixing plane calculation | ales | FLUENT | 0 | February 9, 2005 04:48 |
