Error by compiling scotch for OpenFOAM-1.6-ext |
November 29, 2010, 12:23 |
Vilmar
Hallo,
I try to compile OpenFOAM-1.6-ext and the following failure by compiling scotch 5.1.10b appears: make[2]: Entering directory /OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/scotch_5.1.10b/src/libscotch' gcc -O3 -fPIC -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_PTHREAD -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -DSCOTCH_RENAME_PARSER -DSCOTCH_PTHREAD -Drestrict=__restrict -DSCOTCH_VERSION=5 -DSCOTCH_RELEASE=1 -DSCOTCH_PATCHLEVEL=10 dummysizes.c -o dummysizes -lz -lm -lrt /usr/bin/ld: cannot find -lz collect2: ld returned 1 exit status make[2]: *** [dummysizes] Error 1 can someone give a feedback to this problem? |
November 29, 2010, 12:28 |
Vilmar
Ok,
problem is solved by installing zlib1g-dev! |
Help Compiling OpenFOAM 1.6 on SGI Altix Machine | deji | OpenFOAM | 11 | February 16, 2011 11:10 |
Errors of compiling OF 1.6 on Fedora 12 | maolongliu | OpenFOAM Installation | 2 | May 1, 2010 03:11 |
ODETest.C Compiling failed in version 1.6 | sxhdhi | OpenFOAM Bugs | 4 | April 27, 2010 05:36 |
OpenFOAM 1.6 Compiling Error | AustinK | OpenFOAM Installation | 16 | April 2, 2010 10:37 |
