December 1, 2010, 17:09 |
Got trouble meshing
Pierre
Rep Power: 15 |
Hi everyone,
i'm working on a project and i just can't get my mesh working. First of all i'll show you the geometry i'm trying to realize using blockmesh (unfortunately i'll have to use the direct way by the blockmeshdict, instead of importing a cad-model). So in the atachement is the geometry shown in 2D. For shure im creating it 3D. Everything went good and i already saw the mesh in paraview, but then i realized that the little faces from the "turbulenzgenerator" were not addressed. So i wanted to add them in the wall section and Openfoam got me an error. So i thought i got to merge the patches from the neighbor blocks, so they share the cells. So i tried to add them in the mergePatchPairs section. But i don't now if i missunderstood the syntax or what the problem is. So here is my blockmeshdict: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.7.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.01; vertices ( (-340 0 0) (-306.8 0 0) (-306.8 10 0) (-340 10 0) (-340 0 38.1) (-306.8 0 38.1) (-306.8 10 38.1) (-340 10 38.1) (-340 0 76.2) (-306.8 0 76.2) (-306.8 10 76.2) (-340 10 76.2) (-306.8 0 2) (-302.8 0 2) (-302.8 10 2) (-306.8 10 2) (-302.8 0 38.1) (-302.8 10 38.1) (-306.8 0 74.2) (-302.8 0 74.2) (-302.8 10 74.2) (-306.8 10 74.2) (-302.8 0 0) (0 0 0) (0 10 0) (-302.8 10 0) (0 0 38.1) (0 10 38.1) (-302.8 0 76.2) (0 0 76.2) (0 10 76.2) (-302.8 10 76.2) (0 0 -50.8) (4000 0 -50.8) (4000 10 -50.8) (0 10 -50.8) (4000 0 76.2) (4000 10 76.2) ); blocks ( hex (0 1 2 3 4 5 6 7) (50 1 70) simpleGrading (1 1 10) hex (4 5 6 7 8 9 10 11) (50 1 70) simpleGrading (1 1 0.1) hex (12 13 14 15 5 16 17 6) (20 1 60) simpleGrading (1 1 10) hex (5 16 17 6 18 19 20 21) (20 1 60) simpleGrading (1 1 0.1) hex (22 23 24 25 16 26 27 17) (200 1 70) simpleGrading (1 1 10) hex (16 26 27 17 28 29 30 31) (200 1 70) simpleGrading (1 1 0.1) hex (32 33 34 35 29 36 37 30) (800 1 300) simpleGrading (1 1 1) ); edges ( ); patches ( patch Einlass ( (0 4 7 3) (4 8 11 7) ) patch Auslass ( (37 36 33 34) ) empty Leer ( (0 1 5 4) (4 5 9 8) (3 7 6 2) (7 11 10 6) (12 13 16 5) (5 16 19 18) (15 6 17 14) (6 21 20 17) (22 23 26 16) (16 26 29 28) (25 17 27 24) (17 31 30 27) (32 33 36 29) (35 30 37 34) ) wall WandFest ( (8 9 10 11) (3 2 1 0) (15 14 13 12) (18 19 20 21) (22 25 24 23) (28 29 30 31) (32 35 34 33) (29 36 37 30) /*(10 9 18 21) (15 12 1 2) (20 19 28 31) (25 22 13 14) (35 32 23 24)*/ ) patch one /* Patch für merged Patch pairs */ ( (10 9 5 6) ) patch two /* Patch für merged Patch pairs */ ( (6 5 18 21) ) ); mergePatchPairs ( (one two) ); // ************************************************************************* // Thanks anyone who is trying to help me. By the way: the patches in the "wall wandfest" section which are out commentated are the 5 patches which i forgot to define. But Foam didn't wanted them to use. Thanks for your help Leech |
December 2, 2010, 06:05 |
Nakul
Rep Power: 16 |
It woud be better if you try to specify these faces in "wall" patch only, rather than using merge patch pairs. It might be possible that you had defined these faces in wrong order. Have a look at them and also tell what error do you get when you specify those faces in "wall" patch. |
[GAMBIT] Trouble meshing complex VOF geometry | RPJones | ANSYS Meshing & Geometry | 2 | February 14, 2011 18:54 |
importing cylinder doesn't work & meshing trouble | kfk | STAR-CCM+ | 1 | January 7, 2010 03:34 |
Mixed stairstep + submap meshing trouble | Paweł | FLUENT | 0 | August 4, 2006 06:48 |
Trouble with meshing in Pro-am | NALLELI | Siemens | 1 | July 13, 2005 03:41 |
Singularity of grid?Volume meshing vs face meshing | Ken | Main CFD Forum | 0 | September 4, 2003 11:09 |
