How the grading is calculated
Old   December 3, 2010, 05:47
Default How the grading is calculated
Rickard
Rickard.Solsjo is on a distinguished road
If I use 10 cells and 10 cm together with a stretching lets say 2
All cells are initially 1 cm each. Will the smallest cell be 1/2 cm or is it calculated in some other way?
Thx
R
Rickard.Solsjo is offline   Reply With Quote
Old   December 3, 2010, 07:34
Bernhard
Bernhard is on a distinguished road
It is quite clearly explained in the user guide I think: http://www.openfoam.com/docs/user/bl...hp#x25-1440137
Bernhard is offline   Reply With Quote
Old   December 3, 2010, 08:16
Rickard
We talked it over here and assumed they are using some kind of numerical summation
L = sum(n=0,N-1)x(1+n/(N-1)) where in the end we get
x = 2L/3N based on some kind of average in the middle
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
patch calculated inlet idrama OpenFOAM 3 November 16, 2010 04:56
simple question about calculated bc hyperion OpenFOAM 0 August 14, 2010 14:05
[blockMesh] Grading other than simple and edge titio OpenFOAM Meshing & Mesh Conversion 0 March 5, 2008 11:50
Mesh grading problem Y FLUENT 3 March 2, 2005 05:47
