Home > Forums > OpenFOAM
missing p.relax() in pisoFOAM
Like Tree2Likes
  • 1 Post By akidess
  • 1 Post By akidess
Old   December 10, 2010, 12:00
Default missing p.relax() in pisoFOAM
vgalindo is on a distinguished road
One can find at the end of simpleFOAM the code line
/ / Explicitly relax pressure for momentum corrector
p.relax ();
but this line is missing in pisoFoam.C.
Why?
best regards,
V. G.
vgalindo is offline   Reply With Quote
Old   December 11, 2010, 01:59
Nima Samkhaniani
nimasam is on a distinguished road
piso Foam is a transient solution so relaxation can not be true for a transient solution look CFD book you can find more about difference between piso and simple algorithm
nimasam is offline   Reply With Quote
Old   December 13, 2010, 06:04
akidess's Avatar
Anton Kidess
You can also use relaxation with transient solutions, see eg. PIMPLE or transient SIMPLE. However, the whole point about the PISO algorithm is to eliminate the need for underrelaxation. I do agree with you VG. should have a look into a CFD book on this though.
sharonyue likes this.
Old   September 2, 2013, 23:47
Dongyue Li
sharonyue is on a distinguished road
But in pisoFoam.C, we have UEqn.relax(), why UEqn is relaxed?
and whats the difference between p.relax() with PEqn.relax()?
BTW, in Verssteeg'book page196, it said:
As before, under - relaxation is required with the above procedure to stabilise the caculation process.
sharonyue is offline   Reply With Quote
Old   September 3, 2013, 04:02
akidess's Avatar
Anton Kidess
It doesn't really matter that much if you relax UEqn. In fact, you can throw out the solution UEqn completely by deactivating the momentum predictor.
As for your question about the two types of relaxation, this has been answered multiple times in the past, e.g. here.
Page numbers vary between editions of a book, and the quote you give is so isolated it is of limited use to someone without access to the book.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
*Join the OpenFOAM stackexchange Q&A site: http://area51.stackexchange.com/prop...oHPxcPqde7HtA2
Old   June 1, 2015, 05:50
Dongyue Li
Okay, after a long time, I got some documents(Chinese) to talk about this, this is what they said, I tried to translate it:
In SIMPLE, cuz there is an omission of velocity correction of neighbor cells, using this u^' to correct velocity is moderate. But for pressure, using this u^' to correct pressure is exaggerated. Cause we need to do explicit relaxation in pressure field to make pressure correction to be moderate.
For velocity, we need to use relaxation to make matrix solver robuster. Then we use Ueqn.relax.
Looks interesting, shed a light on this but not very strightforward.
Im the translator of OpenFOAM User Guide Chinese Edition! But always newbie on CFD.
http://dyfluid.com/en.html
p.relax(), pisofoam
Thread Tools
Trackbacks are On
Differences in solution method for pisoFoam and buoyantBoussinesqPisoFoam mchurchf OpenFOAM 6 September 10, 2013 23:24
Buoundary Condition for PisoFoam vishal OpenFOAM 4 October 21, 2010 09:17
the result of pitzDaily using simpleFoam and pisoFoam Kr_kim OpenFOAM Running, Solving & CFD 1 March 16, 2010 14:38
Problem with paraFoam ata OpenFOAM 14 November 30, 2009 05:23
Missing tets along line when meshing with ICEM CFD Georges P. Côté CFX 6 March 23, 2006 01:34
