Simulation the flow of river by OpenFoam
Old   December 14, 2010, 00:34
Default Simulation the flow of river by OpenFoam
Wind
fuji is on a distinguished road
Dear all
I want to simulate the 3D steady state flow in river (about 2km) based on about 1000 field -surveyed point defining the bathymetry.
The boundary inlet is the water level.
Could you help me to do it.
Thank you very much.
Fuji
fuji is offline   Reply With Quote
Old   December 14, 2010, 02:38
Bernhard
Bernhard is on a distinguished road
What information do you want to obtain using the simulation?
Bernhard is offline   Reply With Quote
Old   December 14, 2010, 03:29
Cyp
Cyprien
Cyp is on a distinguished road
There is a Shallow water solver called shallowWaterFoam (you can find it in the incompressible directory). I never try it but I think it is a good start to your problem.
Shallow water equations are the classical way to simulate flow in the case where the horizontal length scale is much greater than the vertical length scale. The shallow water equations are derived from depth-integrating the Navier-Stokes equations. In these equations, the water level is a variable of the system.
Regards,
Cyp
Cyp is offline   Reply With Quote
Old   December 15, 2010, 01:24
Wind
Thanks for reply me
Boundary: how do i input the data for it (special temporal variation of water elevation boundary)
In blockmesh file how to input all of blocks
blocks
hex (0 1 5 4 16 17 21 20) (50 4 1) simpleGrading (1 1 1)
hex (2 3 7 6 18 19 23 22) (50 4 1) simpleGrading (1 1 1)
hex (4 5 9 8 20 21 25 24) (50 8 1) simpleGrading (1 1 1)
hex (5 6 10 9 21 22 26 25) (20 8 1) simpleGrading (1 1 1)
hex (6 7 11 10 22 23 27 26) (50 8 1) simpleGrading (1 1 1)
hex (8 9 13 12 24 25 29 28) (50 8 1) simpleGrading (1 1 1)
hex (9 10 14 13 25 26 30 29) (20 8 1) simpleGrading (1 1 1)
hex (10 11 15 14 26 27 31 30) (50 8 1) simpleGrading (1 1 1)
edges
patches
patch inlet
(0 16 20 4)
(4 20 24 8)
patch outlet
(3 19 23 7)
(7 23 27 11)
patch lowerWall
(0 1 17 16)
(1 5 21 17)
(5 6 22 21)
(2 6 22 18)
(2 3 19 18)
patch atmosphere
(12 13 29 28)
(13 14 30 29)
(14 15 31 30)
(8 24 28 12)
(11 27 31 15)
because i have 1000 field -surveyed point defining the bathymetry along 2km river.
all pacth
About shallowWaterFoam i think it has not solved my problem because
I want to simulate the 3D steady state flow in river (about 2km) based on about 1000 field -surveyed point defining the bathymetry. and than i will simulate the secdiment transport in the river. So i must use 3D full.
Give me advice please!
Best regards
Fuji
Old   December 15, 2010, 02:23
Nico T
deniggo is on a distinguished road
Hello Fuji,
I'm working on a same problem, river flow over theoretical as well as measured bedforms. I found a way to create a mesh by using Matlab->Blender->SnappyHexMesh. Maybe it's not the easiest way, but it works and the results a good.
I use Matlab with a stl-file add-on and create stl files for every boundary wall (bedform, inlet, outlet, top, sidewalls). These stl files I merge in Blender and check the face orientation (all should show outside). Afterwards, I use snappyHexMesh to create a mesh.
I'm not sure if OF can handle sediment transport?!
Btw, which method did you use to measure 1000 survey points?
Nico
deniggo is offline   Reply With Quote
Old   December 19, 2010, 22:43
Wind
Thank you very much Nico
it is an excellent idea but I do not know how to use matlap.
Is there other way to enter the input data (e.g. temporal variation of water elevation boundary) ?
If I now study matlap, how long can I use matlap?
please help me!
Thank you very much
Best regards
Fuji
Old   December 20, 2010, 03:17
Nico T
Hi Fuji,
I think at first you need a mesh of your domain, including your bedform, and all other walls... inlet, outlet. Afterwards you can define a temporal water elevation bc at the inlet. I use groovyBC (http://openfoamwiki.net/index.php/Contrib_groovyBC) for this in interFoam (2-phase flow). But, I think there are many other possibilities.
For creation of your bedform, I'm sure you can also use some import functions of CAD-Software. That would make more sense, if you want to use real measured data. But I didn't try it up to now, so that would be interesting for me as well.
Hope that helps,
Nico
Old   December 21, 2010, 23:15
Robert Ong
rob3rt 0ng is on a distinguished road
Hi All,
Do you know where can I find the proper description of what shallowWaterFoam does and that sort of thing?
And is it possible to incorporate this with irradiance (attenuating of irradiance with respect to the water depth)?
Kind Regards,
Robert
rob3rt 0ng is offline   Reply With Quote
Old   December 22, 2010, 01:17
Wind
Thanks a lot Nico,
I will try to use groovyBC.
Could you send me some picture about your method?
Best Regards
Fuji
Help with slug flow simulation. Kes FLUENT 3 November 9, 2019 21:39
Channel flow setup in Large-eddy simulation Weihua Main CFD Forum 6 November 17, 2015 09:33
Different flow pattern between OpenFOAM and CFX AirS OpenFOAM 0 January 12, 2010 07:08
OpenFoam on compressible flow and electromagnetic flow together ? universez OpenFOAM Running, Solving & CFD 0 January 3, 2010 13:08
calculate volume flow from a 2D simulation SimonH. OpenFOAM 0 October 27, 2009 04:39
