--- How to calculate phiMean for each time step ---
hi to all,:)
I want simulate a problem and i need to set outlets 20% and 80%. as i don't have outlets velocities i set pressure to reach desired flow rates from each outlet by try and error. i do this by k-e and reach to answer. but in Rans and LES i should use averaged flows. i need phi mean parameter same as uMean and pMean which is defined in controlDict. How can i tell OF to calculate phiMean for each time step for patches. Thanks in advance, |
Add this to your controlDict file:
functions |
Thanks for your answer.
I tried it. but i don't have phiMean in time steps folders. what should i do? |
i need phiMean or phi which uses uMean.
