direct map vs cyclic
Old   December 13, 2010, 15:39
Default direct map vs cyclic
Nima Samkhaniani
nimasam is on a distinguished road
im going to modeling a two phase-flow which is heated along pipe, my boundary is cyclic in U and alpha but not in p and T so im going to use following boundary
.............wall..................
inlet outlet
.............axis..................
i would like to direct map of outlet into inlet for alpha and U,
alpha:
inlet
type directMapped;
value uniform 0;
setAverage false;
average 0;
outlet
type zeroGradient;
U:
inlet
type directMapped;
value uniform (0 0 1);
setAverage true;
average (0 0 1);
outlet
type zeroGradient;
p:
inlet
type zeroGradient;
outlet
type fixedValue;
value uniform 0;
T:
inlet
type fixedValue;
value uniform 0 ;
outlet
type zeroGradient;
are my boundaries corrects ?
whats the meaning of value,setAverage, and average?
what should be those values for direct map of outlet value into inlet value i want something exactly like cyclic boundary condition for U and alpha?
P.S: i used changeDictionary Dict like below
dictionaryReplacement
boundary
inlet
type directMappedPatch;
offset ( 0 0 4e-5 );
samplePatch outlet;
nimasam is offline   Reply With Quote
Old   December 14, 2010, 04:52
Stefan Herbert
herbert is on a distinguished road
I think so.
The value entry is as often ignored by any solver but holds just the actual value of the faces.
If you want to fix the mass flow through your domain for example you can use the average option. If "setAverage" is set to "true" (as you did for U) the values are mapped from the outlet but are scaled in a way to reach the specified "average"-value. Else this entry is ignored, too. So if you don't want to fix your average velocity to (0 0 1) you should turn off the setAverage-option.
Kind regards,
Stefan
herbert is offline   Reply With Quote
Old   February 15, 2017, 11:58
Michela
bargiola is on a distinguished road
Dear Nima
I've got problem similar to yours: I'm trying to perform a LES simulation in a channel and I would like to reproduce cyclic boundary condition only for U, but not for a scalar release from the bottom of the channel.
Have you managed to use directMappedPatch in the correct way?
Can you help me please?
Thanks in advance
Michela
bargiola is offline   Reply With Quote
cyclic, directmapped
setup problems - LES pipe flow with cyclic BC (1) and direct mapped inlet (2) florian_krause OpenFOAM 22 June 13, 2013 21:25
Cyclic bc. and overlapGgi Pekka OpenFOAM 12 February 15, 2012 07:10
[Commercial meshers] Handling cyclic BC from gambit to openfoam for a cascade airfoil problem - OF 1.6 maverick OpenFOAM Meshing & Mesh Conversion 2 June 18, 2011 04:36
Pressure instability with rhoSimpleFoam daniel_mills OpenFOAM Running, Solving & CFD 44 February 17, 2011 17:08
