Home > Forums > OpenFOAM
Problems installing swak4Foam
Old   December 20, 2010, 07:44
Default Problems installing swak4Foam
Raimonds Vilums
argonaut is on a distinguished road
I try to build swak4Foam, but get errors. Can anybody see where is the problem? First errors are the following:
[swak4Foam]$ ./Allwmake
Making dependency list for source file SurfacesRepository.C
Making dependency list for source file ExpressionResult.C
Making dependency list for source file FieldValueExpressionParser.yy
could not open file FieldValueExpressionParser_stack.hh for source file FieldValueExpressionParser.yy
could not open file FieldValueExpressionParser_location.hh for source file FieldValueExpressionParser.yy
Making dependency list for source file PatchValueExpressionParser.yy
could not open file PatchValueExpressionParser.tab.hh for source file PatchValueExpressionParser.yy
gcc 4.3.3
bison 2.4.3
flex 2.5.35
argonaut is offline   Reply With Quote
Old   December 20, 2010, 11:07
Assistant Moderator
Bernhard Gschaider
gcc 4.3.3
bison 2.4.3
flex 2.5.35
These errors are OK (FieldValueExpressionParser_stack.hh et al are generated by bison/yacc). The first error that gcc throws would be interesting (but good thinking to start with the errors from the top. Appreciated)
Bernhard
Old   December 21, 2010, 09:25
Raimonds Vilums
If you say so, maybe everything is OK? Word "error" is mentioned later and first appearances I copy here. I attached also full warning and error log. I would be glad if you could take a look and say if I have big problems or not.
I would like also to mention that my linux is quite old (and I do not have root rights), but I built lot of usual utilities by myself. Some of them still could be old and making problems, e.g. findutils. btw, "find" is complaining that it does not recognize -L switch. Unfortunately, I could not build newest findutils.
In file included from general/swakExpressionFunctionObject.C:28:
general/swakExpressionFunctionObject.H:40:36: error: timelineFunctionObject.H: No such file or directory
general/swakExpressionFunctionObject.H:56: error: expected class-name before '{' token
general/swakExpressionFunctionObject.H:56: warning: 'class Foam::swakExpressionFunctionObject' has virtual functions and accessible non-virtual destructor
In file included from general/swakExpressionFunctionObject.H:115,
general/swakExpressionFunctionObjectTemplates.C: In member function 'void Foam::swakExpressionFunctionObject::writeData(Foam::CommonValueExpressionDriver&)':
general/swakExpressionFunctionObjectTemplates.C:68: error: there are no arguments to 'verbose' that depend on a template parameter, so a declaration of 'verbose' must be available
general/swakExpressionFunctionObjectTemplates.C:68: error: (if you use '-fpermissive', G++ will accept your code, but allowing the use of an undeclared name is deprecated)
general/swakExpressionFunctionObjectTemplates.C:76: error: 'OFstream' was not declared in this scope
general/swakExpressionFunctionObjectTemplates.C:76: error: 'o' was not declared in this scope
general/swakExpressionFunctionObjectTemplates.C:76: error: 'filePtrs_' was not declared in this scope
general/swakExpressionFunctionObjectTemplates.C:76: error: no matching function for call to 'name()'
Old   December 22, 2010, 04:51
Assistant Moderator
Bernhard Gschaider
Please have a look at the README. Section Requirements. Point 3. If only the compilation of swakSimpleFunctionObjects fails because of this requirement the other parts of swak (groovyBC and funkySetFields) will work fine
Old   February 11, 2011, 12:11
Raimonds Vilums
Late thanks for your reply. I decided to leave university's claster for a while and installed new Ubuntu + OpenFOAM besides Windows on my desktop PC. Installation of swak4foam also was successful and I even run my test case with groovyBC. I guess I have to get used not to pay too much attention to all bla bla bla that is throwen during compilation
swak4foam error
Thread Tools
Trackbacks are On
installing problems QuangDang OpenFOAM Installation 1 July 26, 2010 09:36
Problems about installing OpenFoam-1.6 chiven OpenFOAM Installation 17 November 24, 2009 03:10
problems with installing OpenFOAM 1.6 su_junwei OpenFOAM Installation 8 September 10, 2009 12:54
installing gambit problems aidank ANSYS Meshing & Geometry 1 July 6, 2009 01:06
Problems installing CFX on Sun Unix Platform Haley CFX 2 November 9, 2001 09:52
