dieselFoam tutorial - OpenFOAM-1.6-ext
Hi, I tried to run the tutorial aachen bomb with 1.6-ext but it crashes after a while with the error janaf out of temperature range. That s very strange, since I ve run that tut with other OF versions without problems. Can anyone check if you get the same error? Maybe my OpenFOAM-1.6-ext is not properly compiled. Regards Peter |
Have you made any changes to the tutorial?
If not can you tell what exactly are you doing to run that tut? Are you running the tut provided with OF-1.6.x only? I am not sure why this may be happening but your answers to above questions might make it possible to help you. |
I am using OF-1.6-ext and not 1.6-x. I am using the tut provided by 1.6-ext. This is the error which I get after a while. In the beginning it runs but than it crashes. Furthermore, a case which runs with OF 1.5-dev exhibit the same problem.
That's pretty strange. Usually tutorials run without a hitch. You may try to re-install your OF. Have you tried running other tutorials? If you find a solution to this problem then do post it here. |
Indeed it s strange. Other tutorials run without a problem. I checked the source code of the dieselFoam solver. It is modified to the version of 1.5-dev. Maybe a bug?
Can someone of u check if the tut aachenbomb (dieselFoam) provided by 1.6-ext with OF-1.6-ext runs to the end? I ve tested it on two different systems. |
Did you fix the problem?
Maybe you did change some settings in the injectorproperties? |
No. I didn t :(
Does it work out for you? |
1 Attachment(s)
Hi
I am uploading the aachenbomb tutorial from OF-1.7.1 Try running it with OF-1.6-ext. If you succeed then find out the differences and post them here. |
It doesn t tun neither. The only difference is that in sprayProperties this is adjusted
sprayIteration Quote:
I have the same problem, the tutorial case doesn't work.
I tried to used some personal cases from 1.7.x, which were okay but they don't work on 1.6-ext too, I get the same error. :( |
