testDataEntry
I just did one of the test cases (testDataEntry) which is inside test folder . It is about using dictionary but it simply gives me the error: [farshad@farshad dataEntry]$ testDataEntry /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.7.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 1.7.1-03e7e056c215 Exec : testDataEntry Date : Jan 01 2011 Time : 16:56:17 Host : farshad PID : 5859 Case : /home/farshad/OpenFOAM/farshad-1.7.1/applications/test/dataEntry nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 --> FOAM FATAL IO ERROR: Attempt to return dictionary entry as a primitive file: /home/farshad/OpenFOAM/farshad-1.7.1/applications/test/dataEntry/constant/dataEntryProperties::dataEntry from line 19 to line 20. From function ITstream& primitiveEntry::stream() const in file db/dictionary/dictionaryEntry/dictionaryEntry.C at line 82. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) in "/home/farshad/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::IOerror::abort() in "/home/farshad/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so" #2 Foam::dictionaryEntry::stream() const in "/home/farshad/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so" #3 Foam::DataEntry<double>::New(Foam::word const&, Foam::dictionary const&) in "/home/farshad/OpenFOAM/farshad-1.7.1/applications/bin/linux64GccDPOpt/testDataEntry" #4 in "/home/farshad/OpenFOAM/farshad-1.7.1/applications/bin/linux64GccDPOpt/testDataEntry" #5 __libc_start_main in "/lib64/libc.so.6" #6 in "/home/farshad/OpenFOAM/farshad-1.7.1/applications/bin/linux64GccDPOpt/testDataEntry" Aborted (core dumped) [farshad@farshad dataEntry]$ ------------------------------------------ Thanks |
