interDyMFoam crashes with Segmentation Fault
Old   December 12, 2010, 18:26
Default interDyMFoam crashes with Segmentation Fault
rassilon is on a distinguished road
I am trying to use the dynamic meshing solver interDyMFoam, to run a case, however the solver crashes at the beginning of the run with the following error:
Only call if constructed with history capability#0 Foam::error:rintStack(Foam::Ostream&) in "/usr/OpenFoam/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/usr/OpenFoam/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 Foam::hexRef8::getSplitPoints() const in "/usr/OpenFoam/OpenFOAM-1.6/lib/linux64GccDPOpt/libdynamicMesh.so"
#3 Foam::dynamicRefineFvMesh::selectUnrefinePoints(do uble, Foam::PackedList<1u> const&, Foam::Field<double> const&) const in "/usr/OpenFoam/OpenFOAM-1.6/lib/linux64GccDPOpt/libdynamicFvMesh.so"
#4 Foam::dynamicRefineFvMesh::update() in "/usr/OpenFoam/OpenFOAM-1.6/lib/linux64GccDPOpt/libdynamicFvMesh.so"
#5 main in "/usr/OpenFoam/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/interDyMFoam"
#6 __libc_start_main in "/lib/libc.so.6"
#7 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116
From function hexRef8::getSplitPoints()
in file polyTopoChange/polyTopoChange/hexRef8.C at line 4873.
FOAM aborting
I created the mesh using snappyHexMesh, and checkMesh identifies no errors, however the solver runs perfectly well with the same mesh created in Gambit and converted using fluentToFoam.
Is this a problem with the solver or with the meshing utility? I have not had any problems with snappy before now. I have also tried running the case using interFoam, which seems to work OK, so I think it may be a problem with either the interDyMFoam solver, or a combination of this solver and the meshing utility.
Has anybody else experienced this, and/or have any suggestions that may help me overcome this?
Thanks in advance,
R
rassilon is offline   Reply With Quote
Old   December 12, 2010, 18:48
Retired Super Moderator
Bruno Santos
Greetings Rassilon,
OpenFOAM 1.6? OpenFOAM is already in version 1.7.x! The latest stable release is 1.7.1! There are so many things that have been fixed since 1.6... you better consider upgrading your OpenFOAM installation.
Better yet, you can keep your current 1.6 and add the latest 1.7.1 and/ot 1.7.x version to your tool belt! Check this post for more information on how to have more than one OpenFOAM version: OpenFoam Installation in Redhat Enterprise linux 5 post #17
Now, if your case still crashes with 1.7.1 or even 1.7.x, then it's most probably a serious bug! On the other hand, it might be a very simple issue: one of the boundary patches of your mesh has zero faces attributed to it. Therefore, no related points were found. Er, I reiterate, it seems to be in the moving part of the mesh... My best bet would be to upgrade
Best regards and good luck!
Bruno
Old   December 12, 2010, 19:31
Originally Posted by wyldckat View Post
Greetings Rassilon,
Bruno
Hi Bruno,
Thanks for the response. yes, I am still running 1.6, though I have tried it on a 1.7 installation, and I still get the same problem.
Cheers,
R
Old   December 29, 2010, 15:23
Dave
daveatstyacht is on a distinguished road
I had the same error come up in 1.7.1 when I tried to use both dynamic remeshing and dynamic mesh motion (I wanted a mesh that would remesh when it got too distorted from the motion). I am not sure what is causing the problem, but in my case it would run until it got to the first remesh and then it would fail with that error message. I had chalked it up to the effect of mesh motion, but I guess it may be something more to do with the remeshing process itself.
daveatstyacht is offline   Reply With Quote
Old   January 5, 2011, 17:31
Hmmm. In my case, it definitely seems to be something to do with the mesh that is produced in snappyHexMesh. Using the same mesh that is imported from Fluent allows interDyMFoam to run as it should.
It's a real pain, as it makes the advantages of the snappyHexMesh utility pretty much worthless, as we are going to have to mesh by hand in Gambit now.
It's also pretty disappointing that this is an error that has survived through two new versions of the code. I hope that it gets cleaned up for the next release.
R
Old   January 5, 2011, 19:22
Bruno Santos
Greetings to all!
If the issue isn't reported to the bug section in www.openfoam.com/bugs then it's less likely that it will ever get fixed!
By the way, have you considered trying the Project-Extend's OpenFOAM 1.6-ext? I only know that it has more and other features than the official version has, so you might want to give it a try!
Best regards,
Bruno
Segmentation fault when running dieselFoam or dieselEngineFoam in parallel francesco OpenFOAM Bugs 4 May 2, 2017 21:59
forrtl: severe (174): SIGSEGV, segmentation fault occurred therockyy FLOW-3D 7 January 19, 2011 22:52
ParaView segmentation fault only for multiphase gwierink OpenFOAM 9 March 25, 2010 07:23
segmentation fault usker Siemens 5 March 5, 2007 23:14
KIVA and Segmentation Fault Felix Main CFD Forum 2 January 18, 2006 01:24
